Results 1 to 17 of 17
Thread: 02 Firebird Dead/Won't start
01-15-2009, 10:50 AM #1Junior Member
- Jan 2009
- Georgia
Hiya all, glad I found this forum
I have a lil dilema here, I have an 02 Firebird T/A, I was driving home from the gym and my entire dashboard gauges went dead like all to 0 save for the fuel gauge. Speedometer, Tachometer, Volts, etc all went to 0. I didn't dare turn the ignition off. I continued to my house about another 3 miles, when I got inside my garage, I turned the ignition off and went to re start my TA and nothing but silence, no lights, no gauges, no radio.
I checked the battery and found it was reading 3.0VDC, I replaced the battery and went to re start my car. I have interior lights, radio, etc but no start, not even the lil click that I used to get when I turned the key. I do however get solenoid clicking when I disconnect and re connect the battery. Any help tis greatly appreciated
2002 Firebird LS1 Automatic, 46k miles
MichealLast edited by Shamrox; 01-15-2009 at 11:15 AM.
01-15-2009, 11:36 AM #2Senior Member
- Jul 2005
- Jacksonville, FL
Is the new battery showing about 12.7V?
01-15-2009, 11:55 AM #3Junior Member
- Jan 2009
- Georgia
Yes 12.5 VDC
01-15-2009, 12:18 PM #4
Check all your fuses just to be sure.
01-15-2009, 12:37 PM #5Junior Member
- Jan 2009
- Georgia
All fuses under the hood in the engine compartment appear to be good, The relays however I am not sure how to test in a "powered-off" state.
Micheal
01-15-2009, 12:48 PM #6
check the cables (both ends) for corrosion. Is the battery losing voltage when it's hooked up?
01-15-2009, 12:51 PM #7
This is without a doubt, a BCM (Body Control Module). Same exact shit happened to me summer of 2007.
The fuses were all good and it did turn out to be a BCM. Just check your fuses first as a new one with labor cost me $700
Let me know if you need more help
01-15-2009, 01:00 PM #8Senior Member
- Jul 2005
- Jacksonville, FL
Try resetting the PCM, won't hurt.
01-15-2009, 01:16 PM #9Junior Member
- Jan 2009
- Georgia
Cables all good, cleaned up any corrosion, Im fearing a BCM also haha but resetting the PCM, hmmm any advice on how to do that?
01-15-2009, 01:35 PM #10Senior Member
- Jul 2005
- Jacksonville, FL
PCM Reset
Turn key on, don't start car
Pull PCM BATT and PCM IGN fuses in engine compartment
Wait 5-10 min
Turn ignition off
Replace fuses
Worth a try.....
01-15-2009, 03:35 PM #11Senior Member
- Feb 2006
- Orange County, NY
Might be the starter went out. You could check the connections at the starter to make sure they are good.
01-15-2009, 03:42 PM #12
Alternator going bad also does the same thing, Happend 3 times to me.
04 C5 A4 Torch Red - sold
2009 CTS4 Ice Black - sold
2013 1500 Silverado Z71 - sold
02 Z/28 M6 Onyx Black All Options - Sold
2014 Caddy CTS4 - DD
2016 Silverado 2500HD
2020 Caddy XT6
2020 2SS Vert
01-15-2009, 07:12 PM #13
01-15-2009, 07:46 PM #14
01-15-2009, 07:58 PM #15
01-15-2009, 08:36 PM #16Member
- Oct 2005
- San Antonio
Silver & Black- 99 Camaro SS
I've not messed with the BCM so I am not sure of all it does.
If you weren't getting starter (solenoid) clicks when starting but did get them when reconnecting the battery. It sounds like the coil is staying on. That is pulling the battery down...and that wouldn't take too long.
Now I seem to recall he BCM being related to the ignition and ignition-on functions. It would make sense...because solenoids need something closing the switch to them.
Note to all, I'd like to crack a BCM open and see what kind of architecture is in there. Anyone have a bad one?
02-15-2009, 09:29 AM #17Junior Member
- Jan 2009
- Georgia
Ok Im back on this again haha, had to take a break for a lil while. I have read up on possible causes and it sure does appear that I have a BCM failure. I am trying to take it out to get it tested at stealership but cant seem to get it to release from under dash. I have the harnasses unplugged but the module wont slide out...any ideas? It looks like a computer hard drive but in a vertical position under and behind glove box. I pull an tug but I dont want to break anything.
Evrything works fine on car, lights, interior lights, radio, power locks, power windows etc all fine, battery does not lose voltage and reads 12.7VDC. Just no gauges and no crank.
Thanks a millLast edited by Shamrox; 02-15-2009 at 09:47 AM.
Help: Battery Dead..can't start
By molecularmann in forum General HelpReplies: 6Last Post: 08-10-2010, 07:56 PM -
Firebird won't start
By Spikito in forum General HelpReplies: 10Last Post: 08-28-2008, 11:12 PM -
Firebird will not start - HELP
By Scotts SS in forum Firebird / WS6Replies: 1Last Post: 05-11-2006, 09:22 AM -
HAHA, car wont start dead as door nail
By Zboner in forum General HelpReplies: 24Last Post: 02-13-2006, 06:00 PM -
cranking the motor over to start with what sounds to be a dead battery
By superchargedrail in forum General HelpReplies: 3Last Post: 01-16-2006, 06:15 PM
