Results 1 to 18 of 18
Thread: Oil catch can in PVC
08-23-2008, 07:02 PM #1Awaiting Activation
- Jun 2008
- Decatur Al
NBM- 99 Z28
Anyone done the oil catch can in the pvc tube ? If so how.
08-24-2008, 03:07 AM #2Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Routing out of your valley tray into the top of the CC...out of the bottom of your CC to your throttle body. Stock it goes from your VT to your TB. Your introducing the CC in between to remove the oil mist.
08-24-2008, 04:09 AM #3
What about deleting the system altogether? Put the breather set-up on the rear driver side & in the oil cap cover and capping off the tb & left side valve cover?
2002 SLP Camaro SS
Onyx Black
http://www.gmhightechperformance.com/features/0901gmhtp_2002_chevy_camaro_ss/index.html
08-24-2008, 04:25 AM #4
08-24-2008, 06:04 AM #5
08-24-2008, 07:25 AM #6Grand Imperial Wizard
Well if you delete your PCV you have no return from the valley to the TB. But then you run into negative pressure and that causes blowby....so you need the positive crank pressure from the vacuum created by the intake....vacuum comes in handy when your trying to stop
So delete the PCV/Add a catch can so you have the crank pressure/vacuum issue addressed without the oil mist being reintroduced via the TB. Now big cams do the same thing...rob vacuum from the crank.....I run a vacuum reserve canister...many run vacuum pumps.....
08-24-2008, 07:28 AM #7Grand Imperial Wizard
See the yellow hoses running to the vacuum reserve canister....
08-24-2008, 07:30 AM #8Grand Imperial Wizard
Here is a better pic....I have a vacuum gauge on top there....it keeps 12-18 lbs of vaccum in reserve to slow my big ass down after a run.....
08-24-2008, 07:38 AM #9
Thanx for the info.................always learning more............
08-24-2008, 07:40 AM #10Grand Imperial Wizard
Well if you learn something tell me will ya?
08-25-2008, 05:24 PM #11Awaiting Activation
- Jun 2008
- Decatur Al
NBM- 99 Z28
Thanks Sarge, I was told this might be the cause of a little smoke between gears (pvc reintroducing oil into the TB. I'm gonna try it when i get the time.
08-25-2008, 05:41 PM #12
Nice read. Bookmarked for later. Do you have a thread on your car? You definately have one hell of a mod list....unlike the common lid and lt's.
08-26-2008, 02:48 AM #13Grand Imperial Wizard
--------------------GM LQ9 Iron Block---------------------
Tuned by Allen Nelson hanging on in the passenger seat trying to keep his laptop in his lap
Forged Balanced Lunati Crank ------ Walbro 255 Fuel Pump
Mahle Forged Pistons/Diamond Rings----- FAST Fuel Rails
Lunati Forged Rods---------------------- Ford 48lb Injectors
ARP Rod Bolts
SLP Underdrive Pulley
LS6 Lingenfelter Ported High Flow Oil Pump
Clay Smith Cam 238/242, .602/.610 lift on a 114 LSA
Patriot 243 Heads 64cc Chambers flow @ 340 cfm @.640 lift
Patriot Gold dual valve springs .650 lift
Titanium Retainers
ARP Head Bolts
Nick Williams 90mm Throttle Body
Speed Density Tune by Allen Nelson
FAST 90mm Intake
Perma-Cool Remote Dual Oil Filters
Perma-Cool Oil Cooler
Shaeffers Series 7000 10-30w/ dual Amsoil Ea015 filters
Amsoil Cold Air Intake
Pedders Suspension w/Koni Shocks in rear
Driveline Components
3 ½” Extreme Performance Aluminum Driveshaft
Harrop Rear Differential w/KAZ 3:91 Gears
Koni Adjustable Shocks
Pedder Drag Springs
Exhaust
Stainless Works Long Tube Headers 3”
RT Cats
DynoMax 3” Tube
Loudmouth II Exhaust
Transmission
4L65E Stage V High Performance
Built By Finish Line Transmissions
Wood Dale, Illinois
- FLT performance pump
- Cryogenically treated FLT sleeved input drum
- Cryogenically treated input sprag races
- Cryogenically treated low roller race
- Cryogenically treated bearing style reaction shaft
- Cryogenically treated output shaft
- GM 5 pinion planets front and rear
- Wide 2-4 band
- 8 B/W high-energy clutches in 3-4 pack
- FLT beast shell w/bearing
- B/W 29 element sprag
- 4L65 low roller clutch
- Transgo HD-2 shift kit
- Corvette Servo
- Bushing kit
- All solenoids
- Internal wire harness
- Spacer plate
- B/W clutches
- Seal & gasket kit
- Filter
- Updated accumulator pistons
- Set end play to performance specs
- Deep GM pan (n/a C-5 corvette model)
- Sonnax super hold 4th gear servo
- B&M Transmission Cooler
- B&M Transmission spin on filter
- 3800 rpm Stall
- B&M Cooler w/spin on filter
Other stuff......
4 point roll bar
Oil Pressure/Oil Temp/Fuel Pressure/Wideband Air Fuel/Trannie Temp/Water Temp Gauges.
Fenders rolled and 255X40X17 BFG KDWII in rear 235X45X17 in front
13" BAER Brakes
Traction Control Off by default w/ ChimpDaddy circuit board.
Battery relocated to rear.
Custom Paint by Sly Jennings
08-26-2008, 06:54 AM #14
more pics please
08-26-2008, 07:58 AM #15G.M. SERVICE MANAGER
- May 2007
- virginia
navy blue metallic- 2000 z28 camaro
hey sarge whats that bad boy run in the eigth??
4.10 RICHMOND GEARS,LAKEWOOD LCA'S,EATON POSI,EDELBROCK TORQUE ARM,
LAKEWOOD PANHARD BAR,SLP LID,,B&M RIPPER SHIFTER,EDELBROCK STRUT TOWER BRACE,SLP FAN CONTROL,SLP LINE LOCK,17 INCH ZR1S WITH 315 35S AND 275 40S,SLP Y-PIPE,TSP 224/224 112LSA CAM,COMP SPRINGS,TUNED BY FROST @ LSXTUNE.COM
08-26-2008, 08:24 AM #16
08-26-2008, 08:39 AM #17Grand Imperial Wizard
Never ran an 1/8th with the timer on.....did some tuning runs.....10:88et @131mph is the best she has done.....in the 1/4....I just cause grief with the Vette/Viper crowd in Austin/San Antonio mostly
Nothing will run with her that I have found....but you know the old saying
08-27-2008, 05:46 AM #18G.M. SERVICE MANAGER
- May 2007
- virginia
thats awesome !!!! i hope to have mine in the 11s really soon
catch can
By kenro23 in forum General HelpReplies: 12Last Post: 03-05-2011, 07:20 AM -
C6 Corvette Catch Can - Catch Me If You Can
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 07-29-2009, 02:00 AM -
Question: Oil Catch can
By The Silver Goat in forum GTOReplies: 5Last Post: 05-04-2008, 03:22 AM -
PCV oil catch can?
By SilverSteen25 in forum External EngineReplies: 3Last Post: 01-25-2008, 05:30 AM -
WTB Oil catch can
By Stricken1 in forum Parts Wanted / TradeReplies: 1Last Post: 11-22-2007, 09:51 PM
