Thread: Oil Catch can
05-01-2008, 10:42 AM #1
Oil Catch can
How often do you check it a catch can?
05-01-2008, 11:00 AM #2Senior Member
- Sep 2007
- Denton, Texas soon Lafayette, Louisiana
Blue- 2002 Z28 Camaro M6
Mine gets emptied no matter what every oil change which is every 3000 miles or 3 months. So far I have not had more then an ounce at the most. I do take the entire bottom off of mine though instead of draining the can from its bolt to make sure i get a good majority out.
05-01-2008, 05:19 PM #3
Just depends on the type of catch can you use. I usually use a glass type you put on a air compressor line so you can see when it starts to fill up. Unscrew pour out excess than spray out with brake clean.
I have also seen a difference on type of oil used. Some oils tend to mist easier in the under the valley pan so you have more of a oil mist that get's sucked up.
What can are you using. Does it have like a Scotch Brite pad in it to catch oil or what?
05-02-2008, 05:09 AM #4Grand Imperial Wizard
- Retired Outlaw Sum Bitch
I empty mine every oil change ( 500 miles or 10 hours engine run time)....get a tablespoon full each time. The reason you should do this is to keep the can operating at maximum efficiency...the fuller it gets the less efficient.....
05-03-2008, 07:56 PM #5
hey sarge, is there any special reason you change your oil every 500 miles?
05-04-2008, 03:22 AM #6Grand Imperial Wizard
Big ass cam and high compression= fuel dilution.
catch can
By kenro23 in forum General HelpReplies: 12Last Post: 03-05-2011, 07:20 AM -
Pcv catch can
By Rk ws6 in forum General HelpReplies: 14Last Post: 01-07-2010, 08:20 PM -
C6 Corvette Catch Can - Catch Me If You Can
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 07-29-2009, 02:00 AM -
PCV oil catch can?
By SilverSteen25 in forum External EngineReplies: 3Last Post: 01-25-2008, 05:30 AM -
WTB Oil catch can
By Stricken1 in forum Parts Wanted / TradeReplies: 1Last Post: 11-22-2007, 09:51 PM
