Results 1 to 13 of 13
Thread: catch can
03-03-2011, 03:57 PM #1
catch can
this may be a dumb question but i am learning as i go. is a recirculating/overflow catch can what i need for the pcv situation?
03-03-2011, 04:01 PM #2
also what is the difference between a 7 or 16lb. radiator cap
03-03-2011, 04:12 PM #3Member
- Cedars, Pa
White- '02 Camaro SS
03-03-2011, 04:15 PM #4
03-03-2011, 04:17 PM #5Member
- Cedars, Pa
Do a search here you'll find the link. Here is a link to a good guy that sponsors the forum.
http://kyspeed.com/index.php?main_pa...d6be9fce0c33aeLast edited by SSnow; 03-03-2011 at 04:20 PM.
03-03-2011, 04:20 PM #6
03-03-2011, 04:21 PM #7Member
- Cedars, Pa
03-03-2011, 04:21 PM #8Spaz is My Mentor
what ever catch can you get you need it to have this type of design for the internals.
It needs to be able to filter air/oil mix. Most cans have a steel wool in them. As the air/oil flow through the steel wool it grabs the oil. Then the oil drips and collects on the bottom of the can.
Here's what mine looks like.
Installed
You will have a better benefit from a catch can if you install a LS6 Valley Tray in addition. What this does is removes the crappy PCV from around the back of the engine and around the passenger side of the intake. The new tray has an internal PCV system developed for the LS6 and routes it to the front of the engine underneath the TB like so:
Better view of both
03-03-2011, 04:25 PM #9Member
- Cedars, Pa
03-03-2011, 04:29 PM #10Spaz is My Mentor
she runs every week end and then some. Where I live it rains more here then any place in the US. Surprisingly I get very little rust.
I looked back at the pic and that spot was from a leak I had fixed.
03-03-2011, 06:13 PM #11
03-04-2011, 08:51 AM #12Spaz is My Mentor
Catch Can I order from WS6Store for $105. There are many others. KYSpeed sells them and a couple of others do so as well. It comes down to your taste. Ebay has a couple of them too, but I'll have to PM the link to you if you want it.
The LS6 Valley Tray I order from gmpartsdirect.com (Sponsor)
The Part Number is 12577927 COVER, cost me $54.65 plus shipping.
Ever where else it's in the 70's.
You might also want to order a OPSU. It becomes brittle over the years of heat cycles and it doesn't take much to snap it. OPSU sits right behind the intake and the hose that attaches the break booster and the intake sits right behind it. When you go to remove the intake take car with that hose because it will snap the OPSU if you pull hard enough. If you do this mod, PM me and I'll send you all the sticky links to this subject. If you want to look ahead of time they are in the Tech Stickies in this section. To replace this valley cover tray it took me about 4 hrs with a buddy because I took my time. If you have the LS6 block already then you can cut that time down by half.
03-05-2011, 07:20 AM #13
I made my own out of a 7-8 in long piece of 3 in diam exhaust pipe. Welded a bottom plate one it, top plate with a bung for the K&N breather filter & bungs for the the hoses from both valve covers. Just an empty space inside, no filters or anything. Been on the car several years & works good. Has a petcock at the bottom to drain.
Pcv catch can
By Rk ws6 in forum General HelpReplies: 14Last Post: 01-07-2010, 08:20 PM -
C6 Corvette Catch Can - Catch Me If You Can
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 07-29-2009, 02:00 AM -
Question: Oil Catch can
By The Silver Goat in forum GTOReplies: 5Last Post: 05-04-2008, 03:22 AM -
PCV oil catch can?
By SilverSteen25 in forum External EngineReplies: 3Last Post: 01-25-2008, 05:30 AM -
WTB Oil catch can
By Stricken1 in forum Parts Wanted / TradeReplies: 1Last Post: 11-22-2007, 09:51 PM
