Results 1 to 20 of 33
08-19-2008, 04:16 PM #1
I filled my radiator with fluid then its empty?
Today i filled the radiator with fliud then i turned on the car for like 5 minutes or so then i wait til it cools off then its gone? I tried it with water too wat can it be?
08-19-2008, 04:31 PM #2
Any puddles under the car? If not check the oil!!
08-19-2008, 04:36 PM #3Member
- Feb 2007
- austin
Black/Black- '00 Firebird WS6 T/A
just let hte engine run while you fill it up. if it keeps getting lower you'll have some sort of leak somewhere; if it doesn't puddle under the car you've lost a head gasket.
08-19-2008, 04:49 PM #4
08-19-2008, 04:53 PM #5
dam dosent seem to leak no where i havent changed my oil need to change already you guys think its due to an oil change?
08-19-2008, 04:56 PM #6
no no.....sometimes the coolant gets into ur engine and mixes with the oil ....check the dipstick and see the consistancy of the oil
08-19-2008, 04:56 PM #7
No. If you have a blown head gasket it leaks into the oil and the oil looks milky.
08-19-2008, 04:59 PM #8
na my oil looks fine ! just that its time to be change! i think my radiator is mest up through the inside
08-19-2008, 04:59 PM #9
doesnt explain where the fluid is leaking to tho......
08-19-2008, 05:01 PM #10
in the engine coolant it comes out green sometimes so i think its going there!
08-19-2008, 05:03 PM #11
Huh..What do you mean in the engine coolant..
08-19-2008, 05:05 PM #12
cuz when the car is on the its off i open the cap from the radiator then i checked the engine coolant cuz it has it on the side its says engine coolant its like a long flat stick and as i opened it was green!
08-19-2008, 05:06 PM #13
so ur saying that the radiator coolant is being collected in the resivoir? hahaha
08-19-2008, 05:07 PM #14
no ima take pics of were i mean that its green!
08-19-2008, 05:08 PM #15
I'm not sure but it kinda sounds like he is messing with you guys.
Edit: maybe not after all.Last edited by 502ci; 08-19-2008 at 05:31 PM.
08-19-2008, 05:10 PM #16
08-19-2008, 05:13 PM #17
im getting the pics uploaded already hold on
08-19-2008, 05:18 PM #18
HERE IS WERE ITS LOCATED AND WAT IT SAYS AND THE COLOR THE GREEN!!
08-19-2008, 05:20 PM #19
It almost sounds like the thermostat isn't opening and sending the coolant straight into the overflow reservoir..
08-19-2008, 05:21 PM #20
Did you guys see the pics?
Help: Radiator fluid change
By MRivera in forum General HelpReplies: 5Last Post: 07-17-2011, 07:38 AM -
HELP!! Power steering fluid in radiator!!!!!!
By Lonesharkpits in forum General HelpReplies: 23Last Post: 02-16-2010, 07:38 PM -
filled car up then shows almost empty?
By krug07 in forum General HelpReplies: 2Last Post: 10-13-2008, 06:39 AM -
Project Shark Attack C3 Corvette Radiator Install - Radiator Fallout
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 04-03-2007, 09:20 AM -
power steering fluid in radiator
By camaross19973 in forum General HelpReplies: 8Last Post: 03-24-2007, 09:39 PM
