    Member camaross19973's Avatar
    Los Angeles
    blue
    1999 camaro ss #976
    Wink power steering fluid in radiator
    i found the tread but didnt anser my ? what to do when the power steering fluid in the radiator
    Feb 2006
    2002 WS6
    replace the power steering cooler found in the lower rad hose. The flush and refill both the power steering and cooling systems.
    Los Angeles
    blue
    1999 camaro ss #976
    i did but the same thing happen. i bought new radiator and the power steering cooler but no luck
    Feb 2006
    2002 WS6
    Then I have no idea, the cooler is the only way i know of for power steeering fliud to enter the cooling system. do you have an auto or manual tranny?
    Los Angeles
    blue
    1999 camaro ss #976
    i have automatic and thx for the help
    Feb 2006
    2002 WS6
    ok, you said you replaced the rad, was it the rad hose you ment? If it was the tranny cooler in the radiator might have cracked.
    Los Angeles
    blue
    1999 camaro ss #976
    no they first told me it was the radiator and it was not. the power steering fluid was steel going into the radiator so then i changed the cooler but it steel does it the engine oil is cleen and the trnny oil is clean
    Feb 2006
    2002 WS6
    hmm, dunno then, could be residue did you get a full flush including the bottle? it has to be coming from some where and there isn't many places it could come from.
    Los Angeles
    blue
    1999 camaro ss #976
    i was going to take it to dealer for the flush
  1. HELP!! Power steering fluid in radiator!!!!!!
    By Lonesharkpits in forum General Help
    Last Post: 02-16-2010, 07:38 PM
  2. power steering fluid
    By Poppn in forum General Help
    Last Post: 02-20-2009, 11:52 AM
  3. Help: Power steering cooler leaking in radiator
    By ahritchie in forum General Help
    Last Post: 06-19-2008, 08:31 PM
  4. Leaking power steering fluid
    By Orrin's Z in forum General Help
    Last Post: 07-11-2007, 03:10 PM
  5. should power steering fluid be muddy?
    By third_shift|studios in forum External Engine
    Last Post: 12-14-2005, 09:41 AM
