Results 1 to 20 of 24
    Feb 2007
    NC
    '99 WS6
    Question HELP!! Power steering fluid in radiator!!!!!!
    I have spoken with a local mechaninc who claims to have seen this before and is telling me i need to replace something he calls a power steering cooling tube that has gone bad??? I've checked my guides and haynes manual and can't seem to locate the part i need......any info would be GREATLY apperciated
    thanks
    Retired Outlaw Sum Bitch
    What kind of car and trannie are we talking about here? I suck at guessing man
    Member bevenue's Avatar
    Aug 2006
    Tulsa, Oklahoma
    2001 camaro SS A4
    For the parts you might have to go to GM. The power steering cooler is the big part in the radiator hose, in between the motor and radiator on the drivers side. Sorry on pics.
    [SIGPIC][/SIGPIC]
    SS #2988, A4, Navy Blue Metalic, 335HP Dual Dual Exhaust, Chrome 10 spokes, Floor mats, Dash plaque, and SS Grille
    Best ET 13.08 @ 106.1, 2.00 60', with SLP lid
    Feb 2007
    NC
    '99 WS6
    Its A Stock 99 Ws6 If That Hepls - Thanks For The Posts So Far - I Talked To My Local Gm Dealership And They Basically Tell Don't Have A Clue
    Feb 2007
    NC
    '99 WS6
    Quote Originally Posted by bevenue View Post
    IS IT ALUMINUM?? PART OF THE HOSE THAT COMES OUT OF THE RADIATOR ON THE DRIVER SIDE AND RUNS BACK BEHIND THE RADIATOR. ALUMINUM PEICE IS ABOUT 8 INCHES LONG??
    THANKS FOR HELP
    Aug 2006
    Tulsa, Oklahoma
    2001 camaro SS A4
    Quote Originally Posted by Lonesharkpits View Post
    THANKS FOR HELP
    Yes, thats the power steering cooler. My guess is something inside is cracked or broken. Although I've never seen how it comes apart. Thats the only way power steering fluid can get into the engine coolant.
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    It looks like just part of the radiator hose until you look a little closer and notice the power steering hoses going to it. I didn't realize this for a while myself until I saw a diagram one day and then went and took a closer look.
    Feb 2007
    NC
    '99 WS6
    Question
    i don't see any other hoses running to the peice i have located, i'll look again. any other directions as to where to look. thank again for all the help
    Aug 2006
    Tulsa, Oklahoma
    2001 camaro SS A4
    Heres some pics of the power steering cooler.
    San Antonio, Tx.
    2001 T/A WS-6
    I just went through the same thing with my 01 T/A. The guy who helped me replace the P/S pump decided to bypass that cooler and go with a Transmission cooler instead.
    There's a link off of ProjectTransAm that should help you with this incase you're interested. The car that this was done on is a 98 Z28. I hope this helps.
    http://para.noid.org/pscooler/
    Feb 2007
    NC
    '99 WS6
    Talking
    i REALLY appreciate all the help - i guess i found it, the whole ordeal just seems crazy, being even possible to have power steering fluid pumped into the radiator is nuts!!! hopefully i'll be back on the road soon
    thanks again
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    You are not driving a typical car despite it being a Chevrolet. Not all cars have power steering coolers.
    Member imflyn's Avatar
    Indy
    '07 Silverado
    Shoot, not even all LS1 f-bodies have the power steering cooler.
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    Really? Which ones don't?
    Indy
    '07 Silverado
    Well, mine for one. I'm not sure if it was dependant on year, or options, or what. I think that maybe the ws6 and SS got them for sure but this is kind of a curious question. Anyone know for sure the rhyme or reason for the cars with or without steering coolers?
    Aug 2006
    Tulsa, Oklahoma
    2001 camaro SS A4
    WS6, Firehawk, and SS = Mandatory option
    T/A, Formula, and Z-28 = Option
    RPO # V12
    Not sure about the V6 cars
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    Well I learn something new every day-I assumed because my car had one that all LS1 F-bodies did. My car has almost all the options (missing the power antennae and 6 disc CD changer) so today I learned it has other options I didn't know were optional. Thanks for the info!
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    Just ran across something to deepen the mystery possibly. I have an options list that I copied back in 2001 (before I bought my 2002 Z-28) that lists the power steering cooler as standard equipment in the Z-28. It shows that when you went from the 'base coupe' (V-6) to the Z-28 (LS1) you got the power steering cooler automatically (along with other standard Z-28 stuff). Just thought this was interesting and remembered this thread. Any thoughts?
    Member Tony180a's Avatar
    Clarksville, Tn
    1999 Trans Am WS6
    I had the same problem with my 99 WS6. After 3 different pontiac dealers and a lot of loot I was told that a coolant line in the radiator hose had ruptured and thats how my system was getting contaminated. My coolant dipstick looked like it had been dipped in elmers glue.
    San Antonio, Tx.
    2001 T/A WS-6
    Tony180a,
    How did you go about getting your system cleaned out? Did a simple flush and fill get the job done? Did you do it yourself with a Prestone flush/fill kit or did you take it in to a shop and have it done?
  1. power steering fluid
    By Poppn in forum General Help
    Last Post: 02-20-2009, 11:52 AM
  2. Help: Power steering cooler leaking in radiator
    By ahritchie in forum General Help
    Last Post: 06-19-2008, 08:31 PM
  3. Leaking power steering fluid
    By Orrin's Z in forum General Help
    Last Post: 07-11-2007, 03:10 PM
  4. power steering fluid in radiator
    By camaross19973 in forum General Help
    Last Post: 03-24-2007, 09:39 PM
  5. should power steering fluid be muddy?
    By third_shift|studios in forum External Engine
    Last Post: 12-14-2005, 09:41 AM
