Results 1 to 13 of 13
Thread: when it blows, what breaks?
08-19-2008, 06:15 AM #1
I hear about guys wrecking their 10 bolt's all the time. what is the weakest link?
I think I heard somthin about how you break the carrier before the axles. what spline are stock 28?
09-03-2008, 03:43 PM #2
seriously? I know guys here have blown up rear ends!!!!!!
just tell me what broke!!!! please! I need to know what I need to do to go low 11's maybe high tens reliably.
09-03-2008, 03:55 PM #3
09-03-2008, 03:58 PM #4
okay, thats what I was thinkin. a built 4l60, and a new rear end.
what would be better for an automatic car on nitrous? a 9", 12 bolt, or S60?
09-03-2008, 04:08 PM #5
09-04-2008, 03:10 PM #6Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
I've destroyed two ring gears...one I shot through the casing and the other I stripped 4 teeth off of
09-04-2008, 05:45 PM #7Junior Member
- Jul 2006
- georgia
NBM- 2000 Z28 A4 273 gears
The 9' ford gets my vote. I have a 9' in my 69 nova with a 454 big block. Never gave me any trouble what so ever.
09-05-2008, 01:33 PM #8
this might help
http://www.sunrayengineering.com/nine.html
09-06-2008, 05:29 AM #9
well, heres the deal. I officially am gonna make it a 383, with mild heads, hot cam, and a 200 shot of nitrous.
that shouldput me mid to high tens......
and after checkin out the link, I think I will be better off with the 9". the 12 bolt and 9" are about the same price, so why not just overbuild it now, and never worry about it later right?
09-07-2008, 07:33 PM #10
I put an Eaton 3 series posi unit 3.73 in my T/A, and it lasted three passes. On the fourth pass the side gear in the carrier broke broke in three places and the axle on the driver side spun, taking out the spider gears and posi clutches. The car only ran high 12's with 1.80 60' times. Auto with 3200 converter and M/T street radials. The 10 bolt 7.5" is definately a weak link.
09-07-2008, 07:40 PM #11
I ripped 5 teeth off the ring gear in a 10", and it was behind a 4.3L V6.
Luckly, I have yet to have a problem with this one. I'm not going to upgrade till this one bites the dust. I think the hard lauches wears stuff out more so than just normal driving.
09-11-2008, 12:14 PM #12
Stripped two gears off aftermarket 4.10s in a stock 6-speed. No clutch dumps, no track use.
My vote is for a Moser 9".
09-14-2008, 12:02 PM #13Member
- Oct 2006
- Springfield
Silver- 2004 SVT Cobra
When i busted the 10-bolt in my trans am it destroyed the gears along with the carrier. Had i took it in before it blew i wouldnt have had to replace the carrier.
In Russia, You cut off Bus, ...Bus Breaks You!!!! (vid)
By wileyCoyote in forum Almost Anything GoesReplies: 7Last Post: 02-28-2013, 05:58 PM -
Help: problems with my breaks
By TransAmFanatic in forum General HelpReplies: 7Last Post: 02-05-2010, 02:13 PM -
Breaks: How low is too low?
By xAgentP in forum Wheels and TiresReplies: 3Last Post: 01-15-2007, 06:23 AM -
What breaks in the rear end.?
By sqwillis in forum DrivetrainReplies: 4Last Post: 04-14-2006, 06:08 PM -
Stock Breaks
By third_shift|studios in forum Suspension and HandlingReplies: 2Last Post: 01-18-2006, 09:00 AM
