Thread: What breaks in the rear end.?
04-14-2006, 10:16 AM #1
Just a quick question:
I want to know what people have broken in there 10 bolt rear ends.
I hear its the ring on a lot.
Any info will help.
04-14-2006, 12:44 PM #2Space Cadet
- Nov 2005
- Port St. John, FL
Red & Dk Gray- 2002 WS6, '08 G8 GT
On my car (the IROC with stock open diff.) I broke the small bolt that secures the Large Centering Pin that keeps the axles from walking. The bolt sheared and the pin tried to walk out until it smacked the Pinion Gear. The Carrier cracked from the pin hole to the open window. Upgraded to an Auburn Carrier, 3.73:1 ratio & a TA Cover.
A co-worker of mine blew his 10" up. (S-10 Pickup with a 383) During a hard launch at a Texas street race, he busted the carrier bearing cap and the axle. What happened as that much torque is applied to the Pinion, it tries to push the Ring Gear and Carrier away from it. The stress broke the Drivers side bearing cap and snapped the axle like a broom stick. It also sheared all the teeth off of the Pinion as it chewed on the ring gear. What a mess. Tore up the inside of the housing as well.
Preventing this type of failure that a TA cover is good for. See Link:
http://www.installuniversity.com/ins...id_install.htm
04-14-2006, 01:11 PM #3Story of My Life!!
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
Got one sitting at the house ready to go in my.
04-14-2006, 04:38 PM #4Space Cadet
- Nov 2005
- Port St. John, FL
I assume you are referring to the TA Cover?
Originally Posted by BIG D's SS
Here is mine, in the '02 WS6;
Yea, I know, eeeuuuwwww! Stock Exhaust! Gonna finish my suspension mods first, then go for power adders.
04-14-2006, 06:08 PM #5Junior Member
- Louisiana
- XX
Under extreme load, the bearing cap bolts will stretch. That along with deformation of the caps and housing make the contact pattern between the pinion and ring gear distort. Then.... POP! Goes the ring gear. This deflection is what the TA cover helps to reduce.
In Russia, You cut off Bus, ...Bus Breaks You!!!! (vid)
By wileyCoyote in forum Almost Anything GoesReplies: 7Last Post: 02-28-2013, 05:58 PM -
LS vs LT Style Rear breaks??
By SMWS6TA in forum General HelpReplies: 4Last Post: 02-14-2012, 07:20 PM -
Help: problems with my breaks
By TransAmFanatic in forum General HelpReplies: 7Last Post: 02-05-2010, 02:13 PM -
Breaks: How low is too low?
By xAgentP in forum Wheels and TiresReplies: 3Last Post: 01-15-2007, 06:23 AM -
Stock Breaks
By third_shift|studios in forum Suspension and HandlingReplies: 2Last Post: 01-18-2006, 09:00 AM
