Results 1 to 20 of 23
Thread: Need help picking a cam.
08-15-2008, 10:22 AM #1
Was looking a t cams today....where the h3ll do i start. i want some with power but still being able to drive if it is colder out nice winter day or something. i all ready know i will need a tune. so power lope is fine too. any advice to help me pick one.
08-15-2008, 10:23 AM #2
oh ya and and i was looking at intakes. ls6 or FAST.
08-17-2008, 03:39 PM #3Member
- Oct 2005
- RI
Mag Red- 2002 Vette
One of the worst mistakes you can make is having someone pick a cam for you. Take a read at this link and get a little smarter on cams, it will help you trade-off the different specifications as any cam is a compromise. You also should be brutally honest with yourself as to what you are looking for from the car, while a nice lumpy idle can sound good, it also presents driving issues. If your car is an auto, too much cam can require a converter. Get smart on cams then start looking around.
Link
08-18-2008, 02:44 AM #4
Yeah read up on it give some cam comps a call and see what they say that can grind for your spec wants
08-18-2008, 09:25 AM #5
just looking for some help i have called some techs but nothing beats a LS1.com members. they give me a bunch of run arounds. but no one knows as much about cams for ls1 cars but the owers of a ls1 with a cam.
08-18-2008, 09:32 AM #6
what are your goals? current mods? future mods in mind?
a 228R is a good all around cam, so is a 224 (what im running). great power under the curve. not PEAK HP making cams. good daily driver manners, etc. smart move would be to address the suspension before adding power...
i can tell you from personal experience, forget the LS6 intake and go FAST 90 or 92, unless you plan to run forced induction, then use an LS6 intake.
you will be fine w/the Ls1 intake for the time being until you get heads, then swap out intakes...2018 CTS-V: °°668rwhp/658rwtq°°
2013 ZL1: °°590rwhp/576rwtq°°
08-18-2008, 10:00 AM #7King 0f n00bz
- Jan 2006
- Shepherd, Michigan
hmm also tho..the new 92/92 is supposed to be stronger now and if you do want to go FI ..you need to get the burst panels..i believe its an extra 150 bucks
08-20-2008, 05:15 PM #8Senior Member
- Nov 2007
- Philly, PA
Black- 2001 Firebird TransAm WS6
so after reading most of this article it puts a lot of emphasis on the size of the valves in relation to the size of the cylinder. so im guessing this means if i plan on doing heads in the future i should consider this, or maybe wait and do both at the same time so they can be paired properly?
08-20-2008, 05:19 PM #9
08-20-2008, 05:23 PM #10member since may 2000
- Dec 2002
- n/w chicago
i did that a few years back when i was about to do a cam.
if i would of listened to the tech guy, i would of fucked up my motor quickly after installing the cam.
long story short, i had 1.85 rocker arms and the guy was telling me to get a cam at 590 lift or close to that.
08-20-2008, 05:28 PM #11
08-21-2008, 12:00 AM #12
08-21-2008, 12:08 AM #13
look up texasspeed.com they are very helpful and cane tune your car
[/SIGPIC]granatelli mafs,slp cold air pkg,smooth bellow,ported tb, msd ignition,lt pacesetter headers,off road y pipe,lm2,100 shot.4l60e by performabuilt transmission level 3 3800 stall and 3.73's gears,cut outs, bmr suspension , control arms, phb, sub frame connectors,3.5 aluminum drive line
08-21-2008, 05:27 AM #14
to support what power you currently have and it will only help down the road once power mods are on the car. that way you know your drivetrain can handle the extra power...
subframes, LCA's, PH bar, TQ arm, 12 bolt or 9", springs/shocks, poly transmission/engine mounts, etc...
08-21-2008, 05:39 AM #15King 0f n00bz
- Jan 2006
i'm with stupid minus the PH bar and the Tq arm...it all depends on if he is having wheel hop issues ..if he isnt getting wheel hop there really isnt a need to get a tq arm until the issue arrives(my opinion)..however get the lca and relocation lca brackets, shocks and mounts. Its important for the person to know that if he gets lowering springs..that it will upset the geometry of the suspension...thats when the relocation brackets and the lca's are required...since traction issues will appear..after which i am sure he might still get wheel hop..which means a tq arm might be required....but like brian said....first get sfcs,shocks, lca and relocation brackets.....if you are keeping your stock rim size and dont feel like lowering the car then stick with the stock springs..for drag racing they are actually pretty nice...but if larger rims and lowering are in your plans..then the PHB will be required to center your rear and the other supporting suspension mods to address the balance issue.
sorry for the novel
08-26-2008, 06:06 PM #16
will a magic stick three work? thats what i think will work good.
08-27-2008, 06:59 AM #17Member
- Mar 2007
- NC
NBM- 1998Z28
First off don't get in a hurry and buy a cam you'll regret later. Texas Speed is getting ready to test a bunch of different cams/heads on a stock 347 motor. My suggestion would be to wait and see what their results are and pick your best option from their testing.
TSP 347 SB, TSP Stage 2.5 PRC LS6, TSP MS4, Performabuilt Stage 2 4L60E, Yank PT4000, 4.11s, Fast 90/90, FTRA Cold air intake+all the free mods, Dynatech Supermaxx Exaust System, DMH Cutouts, Hooker Catback/FTRA Tips. Tuned by RPM/Garner NC. 11.28@119
08-27-2008, 07:42 AM #18
stock motor is a 346, not 347. a forged 347 can yield drastically different results that the stock 346 Ls1 block...
08-27-2008, 07:50 AM #19Senior Member
- Sep 2007
- Denton, Texas soon Lafayette, Louisiana
Blue- 2002 Z28 Camaro M6
My best advice for picking a cam is do lots or reading, phones calls, and talking. Then eventually you will get a better idea of what you want. I know when I was picking out this cam I used something like 300 of my cell phone's minutes just talking to different people, and that was just the different shops. Even more time was spent talking with all my friends.
08-27-2008, 08:10 AM #20
i have talked to alot of people. techs from ws6 store. comp cams. haven't tried texas speed. shops after shops. how well do you like the ms4 PFM?
picking up a 96 WS6
By krese in forum Firebird / WS6Replies: 24Last Post: 08-11-2010, 06:00 PM -
Help: I need help picking a cam....
By chieftransam in forum Internal EngineReplies: 2Last Post: 04-13-2008, 12:14 PM -
Help Picking a cam..
By 99BlackTransAm in forum Internal EngineReplies: 8Last Post: 06-09-2007, 11:03 PM -
Picking up MAF
By Snake Eater in forum External EngineReplies: 0Last Post: 03-07-2006, 04:58 PM -
Need help picking out picking out brake rotors
By Thewilldog in forum Wheels and TiresReplies: 19Last Post: 12-15-2005, 05:52 PM
