Results 1 to 20 of 20
11-09-2005, 02:30 PM #1
Need help picking out picking out brake rotors
I'm sick of the stock discs warping after 6 mo. Is there a good set of after market (slotted, drilled, whatever) that last longer then the lousy stock rotors?
11-12-2005, 01:28 AM #2
Depends on how much $$ you want to spend & how you plan to use your car.
Personally I went with the Baer GT setup that included the Eradispeed 2-pc front rotors and the Eradispeed rear rotors - both crossdrilled and slotted. This setup uses the larger PBR calipers and the front rotors are both larger in diameter and thickness. Setup cost $1500 on sale.
The next step up is to go with the 6-piston calipers and runs over $2K
You can buy just the Eradispeed rotors for use with stock braking system for less $$.
Before Baer I used Powerslot rotors (only slotted) never had any trouble with them warping and liked them - just needed a little more stopping power to go with the increase in hp/tq!
11-14-2005, 07:50 AM #3
Ahh, well I'm not looking for a big investment here. I don't have a stopping problem, only a warping problem. I looked at powerslot rotors. Do you need special pads if you go with slotted rotors?
11-14-2005, 08:06 AM #4
Any type of ceramic pads would be good, low dusting etc. When I had the Powerslots I was running Raybestos QuietStop pads on the front & GM Durastop Pads on the rear.
I now have the Hawk HPS with the Baer Setup - but I think I'm going to go back to the above mentioned pads - HPS seem too hard for my use - I just started getting some brake squeal which I never had with the other pads and it annoys the snot out of me
11-14-2005, 08:27 AM #5Story of My Life!!
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
Call Wholesale Direct Parts. They was running a sale on Power Stop crossdrilled/Slotted with pads for 300 shipped. That sale ended Friday, but I'm sure you can still get a good deal on them. 7146668585.
11-15-2005, 10:18 AM #6Junior Member
- BC Canada
Black- 1998 Chevrolet Camaro
There is another option.If you have 17" rims you can go to LG Motorsports and purchase some caliper brackets that allow you to switch to larger C5 rotors which from what I've been told have no problems with warping. You can even upgrade to C5/Z06 calipers later if you wish. Another bonus is that you can purchase C5 rotors from gmdirect.com for not much more than $20 each.Remember though that you must have 17" rims for this mod.
Originally Posted by Thewilldog
Here's a list of part#s and prices that we're posted at LS1TECH by 92SilverSHO
12530682 / 1 / Caliper (standard C5) - $87.82 (Guide pin bolts included)
12530683 / 1 / Caliper (standard C5) - $87.82 (Guide pin bolts included)
88895128 / 1 / Caliper (Z06) - $85.07 (Guide pin bolts included)
88895129 / 1 / Caliper (Z06) - $85.07 (Guide pin bolts included)
12455799 / 2 / Pad abutment bracket - $27.68
10333772 / 2 / Front caliper brake hose - $19.71
12530697 / 4 / Pad abutment guide pin - $3.44
12530703 / 4 / Guide pin boot - $2.87
22163795 / 2 / Banjo bolt - $2.32
10139097 / 4 / Banjo bolt copper washers - $0.36
12480154 / 1 / Hawk HP+ pad set - $94.50
18039366 / 1 / Durastop Front pad set - $45.20
88909667 / 1 / Durastop Ceramic front pad set (w/springs & shims) - $49.88
88952008 / 1 / Z06 front brake pad set (w/springs & shims) - $97.52
Right front low cost durastop rotor - 88925547 $18.81
Left front low cost durastop rotor - 88925548 $18.81
I got the price off gmdirect.com.
also if you want a package price which when you include shipping call this guy up and say you want the c5 brake upgrade kit.I think the basic kit is like 400, then you can change pads or whatnot with him, he will give you probably the best price on everything shipped!
Gale McGrew
Team Chevrolet,Olds,GMC,Jeep,Nissan
2014 E. 20th Place
Scottsbluff, NE 69361
800-658-4017
Fax 308-632-0974
Email: [email protected]Last edited by ls1geezer; 11-15-2005 at 10:32 AM.
11-15-2005, 02:43 PM #7Alcohol Injected
- Nov 2005
- Knoxville,Tn
Black- 1999 Pontiac Firebird
Running a Ceramic Pad will reduce warping as they run cooler by design. -Powerslots are good to use with them. Just be ready for reduced brake performance -Tim
11-21-2005, 05:36 AM #8Well, I've been using ceramic pads since I've owned the car. Problem still persists. I've already had the rear rotors, pads, calipers replaced by a shop. Still have some vibration though, and now the brakes moan when I stop. I don't think they bled the lines properly. Guess I need the front set up replaced again too. It's only been 18 months since I did that last time
Originally Posted by PaganEgyptian
11-21-2005, 05:42 AM #9
i run powerslots and it is a good feel and it fits with everything stock
11-21-2005, 12:27 PM #10
I have the wholesale direct rotor setup...slotted and drilled. For the money, not bad. I do however have a very mushy brake pedal. Does that have to do with the brakes I installed? dunno.
They're not cracked, still work fine. I don't drive it everyday tho. But I have had a lot of high speed stops.
11-25-2005, 06:22 AM #11Junior Member
- Oct 2005
- Morris County NJ
Red- 2002 Camaro SS
If you don't want anything fancy, I have been very happy with the Brembo OEM replacement blank rotors. They were like $50 each, and I run stock pads. I bought them from TireRack.
My stock rotors lasted about 8,000 miles. The Brembos have 20k on them now and are nice and smooth.
11-27-2005, 09:58 AM #12Junior Member
- Nov 2005
- philadelphia pa
black- pontiac transam ram air
powerslot does the job, no more warping problem for my 1999 transam i put it on with powerstop crossed drilled rotors fit all 16" wheels
11-27-2005, 10:44 AM #13
i love my power slots also.
11-28-2005, 07:21 AM #14Senior Member
- Nov 2005
- Cypress, Texas
Burple- 1966 427 Cobra Replica
I'm just gonna keep turning my rotors until they get too thin to turn anymore then I'm swapping the system for a C5 conversion. Those Baer systems are sweet but a conversion kit is about half the price. And if you want, you can always use Baer rotors on the C5 system.
12-07-2005, 05:39 PM #15Junior Member
- Nov 2005
- Sedalia, MO
silver- 2000 WS6
so noone has really said anything about the Eradispeed rotors and thats the ones i had been looking at. Any complaints with these?
12-08-2005, 12:14 AM #16No one?????????Depends on how much $$ you want to spend & how you plan to use your car.
Got no complaints with my Eradispeeds
12-15-2005, 09:47 AM #17
No complaints from my KVRs drilled and slotted, with 50k or so on them. Originally put them on my first car and xferred them to this one.
Got them on a GP on this board for a good price as I recall.
Regards,
Darden
12-15-2005, 11:12 AM #18I have 46,000 on my OEM rotors and still stops nice and smooth. Always used the stock replacement pads from GM.
"NO box NO bottle, just brains and throttle"
12-15-2005, 01:04 PM #19
You are lucky - I was until recently with the stock ones. I only had one warp, but I replaced the front ones immediately. Have seen MANY folks with warped stock rotors.
Regards,
Darden02 NBM TA - Mecham New Version Hood/Wing, Jet Hot/Hooker Headers, ProDyno exh, Chrome ROH ZS, Volant, Corvette LS1 MAF, Hotchkis LCAs, STB & Adj. PHR, BMR SFCs, Global West Traclink, SLP Bilstiens, Firehawk springs, B&M Ripper, Moser 12 bolt w/ 4.10s, Eaton Posi, LS1 Edit, Hurst line lock- more.
12-15-2005, 05:52 PM #20
My friend just ordered a set front and rear drilled and slotted rotors from WS6Project for $170. I know people dont like the drilled because can crack and such but for the price they look sweet on and if they dont warp for 1-2 sets of pads then its worth it.
-00BlueTA
need help picking a cam
By silver35thss in forum Internal EngineReplies: 10Last Post: 01-31-2010, 07:14 PM -
Need help picking a cam.
By bballking_2007 in forum Internal EngineReplies: 22Last Post: 08-27-2008, 08:22 AM -
Help: I need help picking a cam....
By chieftransam in forum Internal EngineReplies: 2Last Post: 04-13-2008, 12:14 PM -
Help Picking a cam..
By 99BlackTransAm in forum Internal EngineReplies: 8Last Post: 06-09-2007, 11:03 PM -
Picking up MAF
By Snake Eater in forum External EngineReplies: 0Last Post: 03-07-2006, 04:58 PM
