Results 1 to 11 of 11
    Junior Member silver35thss's Avatar
    auburn, al
    2002 ss camaro
    need help picking a cam
    i want to get 400 rwhp ,, all i have done is lts right now and dyno d at 348 ,,,help me pick a cam and spring setup,, will i have to change lifters, timing chain, oil pump? new at this but i think i can do it
    Member NoscamaroSS's Avatar
    Durant, Okla
    2002 Camaro
    You wont have to change lifters, unless you just want to but remember to do lifters you have to remove heads. Now the timing chain and oil pump would be a good thing to replace while youre in there. Are you a A4 or M6? If youre an A4 then I dont really see you making 400rwhp cam only, but horsepower is just a number id be more concerned on how it runs at the track.
    02 Camaro
    PRC Stg 2.5 5.3's, Futral F14, PP Typhoon intake, True duals, Performabuilt tranny, & 3500 convertor, HSW plate kit.
    *Old Time* 10.90@ 125mph
    auburn, al
    2002 ss camaro
    no im a M6 .. what do you suggest in size of cam,, not to familiar with all the numbers.
    In need of another LS1 00blacktransam112's Avatar
    Aug 2008
    Sutton MA
    2000 Pontiac TA
    for driveability, a 228/228 could get you close with supporting mods. agreed, the timing chain and oil pump are a good idea. but i think a torquer v.2 would get you to the 400 rwhp mark. or you could go with the 233/239 cam (im a huge fan of that cam). as for springs, you could run 918's with the torquer but i'd probably say to spring for the double springs. the added peace of mind is worth its weight in gold i think. good luck with your build. what are your current mods too BTW
    Junior Member 99LS1's Avatar
    Nov 2008
    Michigan
    1999 Pontiac Trans Am
    236/242 would ya need todo injectors with that, 112 LSA
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Use this to figure what fuel injector size will be needed.
    FUEL INJECTOR CALCULATOR
    Build in progress...
    Jun 2009
    coon rapids, MN
    2000TA
    call TSP for a cam springs and push rod combo
    Member marksls1ta's Avatar
    pikeville, kentucky
    1998 trans am
    let me kmow if we can help on the cam package. we are competive on pricing and a board sponsor as well.
    Thanks,
    Mark
    auburn, al
    2002 ss camaro
    do you think i need to change valves with the cam swap?
    Member jb3golf's Avatar
    Zona
    1998 Camaro Z28 Conv. M6
    Quote Originally Posted by silver35thss View Post
    No need to change valves IMO. The horsepower difference from upgrading valves will be minimal.....additionally, you are trying to get to 400rwhp so I would focus more on selecting the RIGHT cam that will get you to your desired goal.
    Jun 2009
    coon rapids, MN
    2000TA
    mileage of the motor determine the need for new lifters and oil pump.
  1. picking up a 96 WS6
    By krese in forum Firebird / WS6
    Last Post: 08-11-2010, 06:00 PM
  2. Help: I need help picking a cam....
    By chieftransam in forum Internal Engine
    Last Post: 04-13-2008, 12:14 PM
  3. Help Picking a cam..
    By 99BlackTransAm in forum Internal Engine
    Last Post: 06-09-2007, 11:03 PM
  4. Picking up MAF
    By Snake Eater in forum External Engine
    Last Post: 03-07-2006, 04:58 PM
  5. Need help picking out picking out brake rotors
    By Thewilldog in forum Wheels and Tires
    Last Post: 12-15-2005, 05:52 PM
