    let the F-Bodies roll jimmybling31's Avatar
    hixson tennessee
    94 camaro z28
    converting to 98-02 brakes on 94 z28
    i need new rotors badly and i wanted to get the ls1 calipers and rotors. is there anything else i would need. (i know pads)
    You will also need spindles and caliper mounting brackets in addtion to the parts you mentioned.
    Contrary to popular belief you do not need to get new brake lines as you can bend the bracket about 90 degrees to point the brake line out (pointing to the outside of the car rather than straight up) to make them work without binding.
    Check for sale sections on websites like this one or ebay for 'conversion kits'.
    hixson tennessee
    94 camaro z28
    thanks that's exactly what i needed. i need to change brakes so this will be a lot better.
    Member JAGUAR5822's Avatar
    San Antonio, TX
    2001 SLP SS Convertible
    When you get the spindles, MAKE SURE they are not bent. If they are, it will mess up your alingment to the point that you won't be able to adjust it even close to stock.
    hixson tennessee
    94 camaro z28
    Quote Originally Posted by JAGUAR5822 View Post
    thanks. i was just gonna buy new ones from the store. just to make sure i got good ones.
    San Antonio, TX
    I never checked, but spindles are pretty big, I think they are going to cost way more than they're worth if you get them there.
    hixson tennessee
    94 camaro z28
    i was expecting 150. I'm gonna check into it. i am doing new wheels first. found some torque thrusts for 500.
  1. Question: converting
    By burnsxxxls1 in forum Camaro / SS
    Last Post: 08-19-2010, 11:01 AM
  2. converting lt1 ecu to Ls1 ecu?
    By Sleeper101 in forum LT1
    Last Post: 04-08-2009, 09:21 AM
  3. Converting DVD to MP3 files
    By ss~zoso~ss in forum Almost Anything Goes
    Last Post: 04-12-2007, 08:06 AM
  4. Converting from 3:42 to 4:10 gears
    By chevelle9 in forum LT1
    Last Post: 11-03-2005, 09:20 PM
