Results 1 to 13 of 13
    Senior Member Sleeper101's Avatar
    Springcity
    Vette,240sx,ls1 camaro
    converting lt1 ecu to Ls1 ecu?
    Alright the guys Im dealing with at the dyno says the Ls1 ecu is xxxx faster and alot more tuneable, they are looking into seeing what it would take to convert. But maybe you guys know. Would the Lt1 wiring harness work? We would like to get rid of the Opti and go to a Ls2 coil setup. If I gotta re-wire the whole car n stuff its not worth it to me. But If its a pretty basic swap were all in.
    Anyone ever attempt?
    Mar 2009
    Pittsburgh,PA
    a guy on tech did it. he used harness from a ls1, i think a front cover from a vortec motor. i dont see it bein a problem since the two motors are similar. its the same prinicple as using an aftermarket system. biggest thing is finding a cam sensor and crank sensor to work and their values
    Rice Killa JwMonE99's Avatar
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Have you thought about maybe switching to a stand alone?
    I know with megasquirt you can get rid of the opti.
    I will be doing this in the next few weeks.
    Springcity
    I have a Megasquirt on my 240, Its a Really awesome Stand Alone, The only Problem is Its not Emissions Legal, Were Looking at making a conversion with it still being legal But yet very Tune-able. Thats Why Were looking into the Ls1 ECU.
    Were Looking into maybe making a ls1 ECU and making a Wiring harness for our Propane cars So they also would pass Emissions and We can Still Tune The car as a Standalone.
    From the way I understand it a Ls1 Computer You can turn what ever you want on and off, So its Ideal for getting threw the Government crap and Still making the Offroad capabilities.
    But then Again it may be a waste of time lol IDK.
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    lol I dont know about all that.
    Here in SC we dont have emissions so I was all for megaquirt.
    Feb 2008
    york pa
    96 ws6
    Didn't think it was possible
    Oct 2001
    Colorado
    95 Z28
    Plenty of guys have tuned wild combinations with the factory LT1 ECU, including turbos, blowers, and all sorts of heads/cam combos. If they can do it, why can't your tuner?
    Springcity
    My Tuner def can tune the Lt1 ecu no problem. The Problem with the Lt1 ecu is its processer speed is as slow as an average honda, If you have a quick reving High hp built motor. They are finding out that the motor is actually out running the ecu so it does not get as good of tune as its capable of. Its just 1 of the problems of why the Lt1 guys cant make as much power as the ls1 guys.
    But Like I said, I was hoping it was just a basic swap, Its not my car its going on so Im not going to spend xxx amount of hours on switching wiring harnesses.
    Mar 2009
    Pittsburgh,PA
    Quote Originally Posted by 5.0THIS View Post
    LS1 computer far more advanced. its like using windows 95 vs windows xp
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Springcity
    Thanks for the info. Had Exactly what I was looking for. But Looks like Too much work involed for me at the moment. Im ready to get this thing Fired up and making some noise, Will deal with the ECU later.
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Yea, for the same amount of work why not just go with the megasquirt? You can get rid of the opti that way too.
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    Quote Originally Posted by Quik View Post
    More like DOS vs Windows XP
  1. Question: converting
    By burnsxxxls1 in forum Camaro / SS
    Last Post: 08-19-2010, 11:01 AM
  2. converting to 98-02 brakes on 94 z28
    By jimmybling31 in forum Suspension and Handling
    Last Post: 08-25-2008, 06:02 PM
  3. Converting DVD to MP3 files
    By ss~zoso~ss in forum Almost Anything Goes
    Last Post: 04-12-2007, 08:06 AM
  4. 98 Trans Am converting to ram air
    By JERRY REID in forum New Member Introductions
    Last Post: 12-05-2006, 10:35 PM
  5. Converting from 3:42 to 4:10 gears
    By chevelle9 in forum LT1
    Last Post: 11-03-2005, 09:20 PM
