    chevelle9
    Guest
    Thumbs up Converting from 3:42 to 4:10 gears
    I've got a 94 firebird with a six speed with 3:42 gear ratio. I wanted to know if anyone has made this swap and if you have did it make a big difference. I wonder if you have to only change the ring and pinion. I want to know if you guys think it would be a worthwhile investment.
    Commerce Ga
    Black, Blue
    07 TBSS, 07 GSXR1000
    I just converted my 00 SS m6 from 3.42's to 4.10's and I love it. Man you will not believe the difference in pickup. It didn't really hurt my gas mileage. I would highly recommend it.
    3 inch Chambered Catback.
    - = LR = - grandkodiak's Avatar
    x
    http://www.ls1.com/forums/showthread.php?t=4250
    Hope that helps... I am now more undecided then when I was originally looking though...
    EVERYONE said go 4.10 but NONE OF THEM had an LT1 car, nor could they give me specifics.
    Right now I'm thinking 4.10 but I'm going to hold off another month to save enough to swap for 3.73's if 4.10 are too much of a pain for the gain so Im not stuck driving 4.10's until I can get 3.73s
    Junior Member Z95SSCLONE's Avatar
    LA
    95 Z28
    4.10s on an LT1 are a great choice. problem is the diff is still going to blow up on ya. i just bought a strange 12 bolt for that reason. (with 4.10s of course)
    lt4ever
    Guest
    I went from crappy stock 2.73's... yes, you read that right <2.73> in my '96 Formula to 3.73's. That was over two years ago... and it's still running strong without any noise or whine or grinding... and I run drag radials at the track. My opinion... get the gears... you'll absolutely love your car all over again. It's a HUGE difference and VERY noticeable!!!! Good luck!
    Junior Member spike30th's Avatar
    west chester,pa
    97 camaro ss 30th
    i changed the gears in my old 95 formula with a 6 speed with bolt ons and stock internals to 4.10s. It all depends I found out on the street it was a good street gear if you are into street racing. But for track use they suck, if you shift your car at redline your going to have to use 5th gear at which your car is going to fall flat on its face. So now I have a 97 camaro ss I got hot cam with full bolt ons and it has 3.73s and now I wish I have did the 4.10s because I shift at a higher rpm and I wouldnt have to shift into 5th. All depends on your mods if you are going to do a cam which you are going to get more rpm out of your motor go with 4.10s if not do the 3.73s . just noticed you posted this awhile ago sorry for the late response
    chevelle9
    Guest
    Thanks for all of the replys to my question. They are very helpful. And if you have any experience with my question don't hesitate to post a reply. Thank You
  1. Question: converting
    By burnsxxxls1 in forum Camaro / SS
    Last Post: 08-19-2010, 11:01 AM
  2. converting lt1 ecu to Ls1 ecu?
    By Sleeper101 in forum LT1
    Last Post: 04-08-2009, 09:21 AM
  3. converting to 98-02 brakes on 94 z28
    By jimmybling31 in forum Suspension and Handling
    Last Post: 08-25-2008, 06:02 PM
  4. Converting DVD to MP3 files
    By ss~zoso~ss in forum Almost Anything Goes
    Last Post: 04-12-2007, 08:06 AM
