Results 1 to 20 of 21
Thread: Cam Choice?
08-02-2008, 10:38 AM #1
Cam Choice?
I am looking at 4 Cams, all the same cost. I am completely cam ingorant so maybe someone can tell me what the best bang for the buck would be out of these 4? Basically I am looking for a very streetable driver. I don't plan on going much over 400-450rwhp, once all my other mods are done.
220/220 .551/.551 112 LSA
220/220 .551/.551 114 LSA
224/224 .563/.563 112 LSA
224/224 .563/.563 114 LSA
08-02-2008, 04:38 PM #2Member
- Oct 2005
- RI
Mag Red- 2002 Vette
Where do you want your power band? Do you plan on heads? Have you considered a package/combination that is known to make power and then only picking up the cam now? How much advance in the cames you have picked?
08-02-2008, 09:57 PM #3member since may 2000
- Dec 2002
- n/w chicago
option #5 is the same cam i have,
the 224/224 581/581 114 lsa.
option #6 is the cam i should of got, 228/2282000 nhra edition formula
a few bolt ons, 379 rwhp
11.96 @113.25
08-03-2008, 05:51 PM #4
I have a 228/228 588/588 112 LSA. Its very streetable and pulls like a raped ape from 2500 to 6500 rpms.
2010 Camaro
2006 GTO, LS2, 1 of 475
2009 Chevy Silverado
08-03-2008, 06:37 PM #5Member
- Jun 2008
- PA
Black- 1999 Formula
i also have a 228/228 cam with 114 lsa tho n its very streetable, putting down 360rwhp and 360 rwtq with this Lid, LT's, ORY
08-03-2008, 06:37 PM #6Member
- Jun 2008
- PA
Black- 1999 Formula
o and slp catback
08-03-2008, 06:53 PM #7
08-04-2008, 04:46 PM #8
None of those cams will get you to 400rwhp without heads. I had the 224/112 cam, made 372rwhp on a dynojet. I got bored with that one.
08-04-2008, 04:51 PM #9
I am pushing 430 to the rear with my cam and ls6 ported heads.
08-04-2008, 06:54 PM #10
Option #7: 230/234 .612/.598 112
I had a 224/224 .581/.581 112 w/ stage 2 pp heads and got 410 through the 10 bolt.
08-04-2008, 07:40 PM #112 SS's are better than 1
- Jun 2007
- Lathrop, Missouri
230/232 604/604 113+1 lsa Here and is absolutely streetable with an awesome 2500-6500 RPM powerband. Daily drive mine.
08-05-2008, 05:10 AM #12
See, I told you all I was cam ignorant!
It sounds like if I go with WS6ICK's set up, I will be right in the rwhp range I am looking for. Thanks for all your suggestions.
08-05-2008, 05:19 AM #13
2018 Tahoe - Silver - OEM
08-05-2008, 05:24 AM #14
08-05-2008, 08:56 AM #15
08-05-2008, 11:24 AM #16
08-05-2008, 11:34 AM #17G.M. SERVICE MANAGER
- May 2007
- virginia
navy blue metallic- 2000 z28 camaro
Im Running Tsp 224/224 .581 112lsa Pulls Like A Madman !!!
4.10 RICHMOND GEARS,LAKEWOOD LCA'S,EATON POSI,EDELBROCK TORQUE ARM,
LAKEWOOD PANHARD BAR,SLP LID,,B&M RIPPER SHIFTER,EDELBROCK STRUT TOWER BRACE,SLP FAN CONTROL,SLP LINE LOCK,17 INCH ZR1S WITH 315 35S AND 275 40S,SLP Y-PIPE,TSP 224/224 112LSA CAM,COMP SPRINGS,TUNED BY FROST @ LSXTUNE.COM
08-05-2008, 05:29 PM #18
08-05-2008, 05:31 PM #19
08-05-2008, 06:14 PM #20
^^^^lol. True!
You could still get any cam listed above and probably make ~400. I made 410 with PP stage 2 heads and the 224 cam through the stock rear while wearing ET streets. I'm make a lot more now with this cam (in sig) and the same heads. I've also seen cam's much larger than mine that people dd. It can happen...just depends on the tune.Patriot Stage II-59cc | little cam-230/234 .612/.598 112 | Hooker LT's l Custom Y-w/cats l Moser 12 l LCA l SFC l STB l K&N l 160 thermo l SLP ud pulley-
l SLP linelock l PRO 5.0 l
Cam choice
By bpk99ta in forum Internal EngineReplies: 8Last Post: 10-22-2009, 06:28 PM -
need help with cam choice!!! thanks
By mglangley21 in forum Internal EngineReplies: 17Last Post: 09-25-2009, 07:02 AM -
Question: How is this cam choice?
By stevenm357 in forum Internal EngineReplies: 5Last Post: 05-28-2008, 05:26 AM -
Oil of choice?
By The_Wretched in forum General HelpReplies: 2Last Post: 01-18-2008, 04:14 AM -
Cam Choice?
By 1CLNSS in forum Internal EngineReplies: 6Last Post: 08-08-2006, 01:25 AM
