Results 1 to 18 of 18
09-19-2009, 11:10 AM #1
need help with cam choice!!! thanks
I have a stock LS6 block and i'm looking to add a CAM to work with my stock setup, i still want good street driveabilty and a little lope not much, and what will i need( push rods, ect) and what is a good size cam( specs)? thanks its and AUTO
09-19-2009, 06:00 PM #2Impounded
- Apr 2006
- park bench
- gmcheviac
Maybe around a 220 cam. I would call one of the sponsors on here, tell them your car setup, and they'll grind an ideal cam for your setup. If your looking to purely make it accelerate faster, being an automatic a higher stall converter will help you alot more than any cam with the stock converter.
09-21-2009, 01:26 AM #3
+1 on the converter.
try to decide on what cam you want first, then get a stall to complement it (most will say 3,000-3,600 for small cam).
trust me, install the converter first.
FYI, I'm running a 220/224 cam, and 3,800 stall. I wish I went with a bigger cam, a good tuner can make a 228 very drivable for you.
at a minimum you will need valve springs,pushrods, tranny cooler and a tune
09-21-2009, 08:59 AM #4Senior Member
- Jun 2008
- Rochester, NY Rochesterracing.com
- 2000 Camaro B4C
+1 for the stall, did my cam then stalled her its like driving a totally different car....but be sure to match the cam and stall
2000 B4C Special Service Package Z28 - Kooks 1&7/8 Stepped 2'' - TSP Torquer V.2 - FAST 92/92 - BDR 4000 Conveter - Xtreme Trans Stage II - Full UMI Suspension - Pacesetter LT's - Comp Drag Shocks - Magnaflow - Cutout - ZO6 MAF - FTP LID - Street Tuned -
09-21-2009, 05:40 PM #5
I have a 3300 stall-3-73 gears-stage 3 trans- auburn posi and standard tune-shift kit-port polish tb-
09-22-2009, 04:35 PM #6
I wouldn't bother putting anything smaller than a 224 cam. Personally I'd go 228 as the drivability will be the same.
09-22-2009, 07:27 PM #7
228 is the smallest I would go really. Many disagree. 224 is no doubt a good cam, but with the tuning skills of so many out there, you can makea slightly larger cam idle normal, Decel normal, Cruise normal, and have more top end power while keeping low end. Gears really help out the low end when swapping cams.
09-23-2009, 02:10 PM #8
09-23-2009, 02:14 PM #9
If you have stock exhaust manifolds your limited especially with stock stall. 218/224 115 lsa 215/230 117lsa. Talk to frost if you are serious.
09-23-2009, 02:15 PM #10
If you have stock exhaust manifolds you shouldn't be looking at cams imo.
09-23-2009, 02:21 PM #11
09-23-2009, 07:12 PM #12
09-23-2009, 11:06 PM #13
09-23-2009, 11:20 PM #14
I'm looking at upgrading to a 240/242 .600/.600 112lsa in a month or two and pulling out my 220/224 .570/.580 112lsa.....its about the size of a hot cam and bumps power up across the rpm range.....it would work with stock manifolds, but like said above, headers would give you better gains
09-23-2009, 11:20 PM #15
09-24-2009, 06:45 PM #16
i just put a 228/228 with 588 lift with 112 lsa and a + 2 adv. works great still gota get it tuned but mine is a 6 speed
09-25-2009, 05:24 AM #17Junior Member
- Jul 2009
- CHICAGO ILL
blue- 1998 Z-28
I got a zo6 cam with push rod from ls7 i had in my ls1 it made 400hp for sale 200.00free shiping
09-25-2009, 07:02 AM #18
Cam choice
By bpk99ta in forum Internal EngineReplies: 8Last Post: 10-22-2009, 06:28 PM -
Cam Choice?
By UKXK189 in forum Internal EngineReplies: 20Last Post: 08-08-2008, 04:33 AM -
Question: How is this cam choice?
By stevenm357 in forum Internal EngineReplies: 5Last Post: 05-28-2008, 05:26 AM -
Oil of choice?
By The_Wretched in forum General HelpReplies: 2Last Post: 01-18-2008, 04:14 AM -
Cam Choice?
By 1CLNSS in forum Internal EngineReplies: 6Last Post: 08-08-2006, 01:25 AM
