Thread: Help after plug and wire swap
07-26-2008, 09:23 PM #1Junior Member
- Jul 2008
- San Jose, CA
Sebring Silver- 1998 Z28
I just finished replacing my plugs and wires (except #8) and after I finished I heard a ticking noise after turning the car off. I'm assuming its just a loose wire, but could it also be a loose plug? I was not able to get a torque wrench in there so I just tightened them a quarter turn past hand tight. How tight should I make the plugs?
07-27-2008, 05:42 AM #2
Why did you leave # 8 in? You have to make your way back there and get it. It sounds like you broke a plug. The porcelin around the plug is VERY tender. Get the panties out of your crack and hit the # 8 plug. J/K. Good luck,take your time, for a first timer it will take about 1 hr just for the # 8 plug. You will get better.
07-27-2008, 05:45 AM #3Senior Member
- Nov 2006
- Indianapolis
Ticking noise after you turn the car off? Sounds like something besides spark plugs, you have to just find it when you shut the car off. And 1/4 turn after they seat should be fine. When I put my headers on, a friend helped re-install the spark plugs, I heard a ticking sound when the car was running, turned out to be a slightly loose spark plug.
07-27-2008, 11:55 AM #4Junior Member
- Jul 2008
- San Jose, CA
Yea thanks for the help. I got to the last plug just having some trouble pulling the wire off the plug. Plus I snapped the wire so I have to get it done today. Any advice to getting more room in there? I took of the coil packs and the AIR pipe. Going to try again later once I'm less frustrated and my arms dont hurt as much.
07-27-2008, 03:39 PM #5
Plug wire recommendations for my LT-1....
By jrgswhitels1 in forum General HelpReplies: 3Last Post: 08-19-2011, 07:53 AM -
Plug and Wire Change
By Raoul-Duke in forum General HelpReplies: 11Last Post: 07-14-2010, 10:34 AM -
Plug wire problems
By Badbird in forum LT1Replies: 8Last Post: 07-26-2007, 02:25 AM -
Plug Wire Removal
By KM02SS in forum External EngineReplies: 7Last Post: 04-11-2007, 07:59 PM -
Spark plug wire and plug!
By RYDER661 in forum General HelpReplies: 2Last Post: 03-13-2006, 09:01 PM
