Results 1 to 3 of 3
Thread: Spark plug wire and plug!
03-13-2006, 08:26 PM #1Junior Member
- Mar 2006
- bakersfield,ca
black- 01 pontiac transam ws6 m6
I just got my new spark plugs I have champion double platinums and denso iridiums which should I use? I want to save gas but I also want the iridium power how much of a difference in timing of the 1/4 mile should I lose if I were to use the double platinums instead of the iridiums? and I need help getting spark plug wire and plug #1 facing the LS1 from the front the others are arm reaching distance but not #1 how do i get that sucker out?
03-13-2006, 08:54 PM #2I've always used NGK TR55's so I can't help you on your plug choice. I'm going to guess you actually mean plug #8 which is the bitch plug to get out with stock manifolds on. Looking at the car from the front the drivers side plugs are 1-3-5-7 and on the passenger side they're 2-4-6-8. #8 being the furthest back under the firewall. It takes some creative hand work to get it and a swivel makes it much easier. The first thing you should do though is pull the coil packs on that side. It's only a couple of extra bolts and makes the whole plug change way easier.
Originally Posted by RYDER661
03-13-2006, 09:01 PM #3Junior Member
- Mar 2006
- bakersfield,ca
thanks for the help man im gonna take out the coils first thing in the morning
Question: Spark plug wire installation
By 2002ssslp in forum External EngineReplies: 5Last Post: 08-27-2011, 10:42 AM -
Question: Spark plug wire heat shield
By SteveCZ28 in forum General HelpReplies: 6Last Post: 03-07-2011, 03:52 AM -
What kind of oil 5w30& spark plugs&spark plug wire
By ROMERO98Z28 in forum General HelpReplies: 20Last Post: 09-01-2009, 01:50 PM -
Wanted: Spark plug wire
By Kaotic_ws6 in forum Parts Wanted / TradeReplies: 3Last Post: 08-19-2009, 07:44 AM -
spark plug wire boots
By 1MileCrash in forum External EngineReplies: 5Last Post: 04-27-2009, 02:54 PM
