    Greene, Iowa
    99 Chevrolet Camaro Z-28
    Spark plug wire heat shield
    Im considering getting new spark plug wires to go with the plugs for my header install...im looking into a set of msd wires...my question is will i need to pull the heat shields off my stock wires and put them on the new msd's or will it be fine without? just curious about this is all, and dont want to melt wires on the new headers
    Nov 2009
    Jacksonville FL
    TRIPLE BLACK
    2000 CAMARO SS M6 #2100
    I reused them with my MSDs and I have heard many people say to do so. I have heard many reasons for doing so with many of them not being that they will melt but to reduce the EMI interference. Either way you can’t go wrong with reusing them to be safe. I have seen a ton of people run without them and have zero problems. Your call I guess.
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    No heat shields on mine for 5 years now, no issues, but mine isn't a DD either.
    I have the 8.5mm Superconductor's.
    Senior Member
    texas
    2000 formula
    did not use the heat shields on my MSDs......or the Granatellis that replaced those.....not a single problem
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    I trashed mine years ago... I figured if they were wet, it would help jump a spark to ground...
    East of Cleveland, Ohio
    99 WS.6 - Modified
    Same here. Got rid of them when I threw the MSDs on. Never had a problem. Just make sure your wires aren't touching your exhaust and you'll be fine.
    I installed a set of DEI Protect-A-Boots on ours when the headers and MSD wires went in. Seemed like cheap insurance at the time and I have not had a problem.
  1. spark plug heat shield
    By 1998 T/A in forum Firebird / WS6
    Last Post: 04-19-2015, 05:40 PM
  2. spark plug heat shield
    By jakez28 in forum General Help
    Last Post: 04-14-2010, 09:29 PM
  3. What kind of oil 5w30& spark plugs&spark plug wire
    By ROMERO98Z28 in forum General Help
    Last Post: 09-01-2009, 01:50 PM
  4. Wanted: Spark plug wire
    By Kaotic_ws6 in forum Parts Wanted / Trade
    Last Post: 08-19-2009, 07:44 AM
  5. Spark Plug Wire Heat Sheilds
    By stevenm357 in forum External Engine
    Last Post: 06-04-2008, 06:12 AM
