Thread: Plug and Wire Change
07-07-2010, 05:34 AM #1
So Im changing my wires at 67k on my 01 Z28 and was wondering if there is anything I need to know except just physically changing the wires and plugs. I know installing the plugs your supposed to go finger tight and turn 1/4 the way w a socket but is there any other pointers you guys can give me?? Like anything to put on the thread of the plug or installation of the wires??
Im going with the MSD wires and NGK iridium Tr55's01 m6 z28 - lid / lt headers / 3' ory w no cats / flowmaster catback w 3' dmh e-cutout / nelson pcm tune
07-07-2010, 03:37 PM #2
Access to the plugs is much easier if you remove the coil packs. I also recommend popping the pins up on the cowl seal with a flat blade screwdriver as they will shred your hands. Before removing the plugs, I always use an air gun to blow any accumulated crap out of the area where the plugs seat in the heads. Plug number 8 is sometimes easier to get at from beneath the vehicle. Also, a 1-1/2" extension is about perfect for the plugs with limited access.
Use a very light coat of anti-sieze on the threads and they should be torqued to 11 ft.lbs. On our car, I could not get a torque wrench on a few of the plugs, so I had to estimate. When you install the wires you should hear one click on the plugs and two clicks on the coil packs. Take your time and do not get impatient -- plug changes can be a bit trying on these cars.
07-07-2010, 04:32 PM #3
07-07-2010, 05:14 PM #4
If your car is '99 up, the coil packs each have one harness connection in the center and a few bolts that hold them to the rocker covers. The worst one to get at is the passenger side rearmost bolt. Some guys actually leave that one out when they re-install the coils. I think the '98s are individually mounted, rather than on a bracket. It's not bad at all and gives you a lot more space to work in for the plug change.
The cowl seal is the rubber strip that seals the back of your hood to the body. It runs across the width of the cowl and is held in place by pointy little pins.
07-08-2010, 01:06 PM #5
07-08-2010, 01:27 PM #6
07-08-2010, 02:28 PM #7Senior Member
- Apr 2007
- Newport, RI
Navy Blue Metallic- '00 Formy A4
It's not that bad unless you have arms like Popeye.
I was going to remove my coil packs, but the last rail bolt was being such a PITA to get to I said the hell with it and left them on. I did fine with them there.
The #8 plug looks like a bitch from the top, and it is, but it's really easy to do the plug and wire from underneath. I actually had a harder time with #6 IIRC.
You also don't need alot of extensions and u-joints, all I used was a .75" & a 3" extension on my 3/8 drive ratchet. The drivers side is cake, although that .75" extension will come in handy there. The pass side, I ended up kneeling on the battery and rad support, bracing myself with my right hand on the intake, and used my left hand to pull straight up on the ratchet.
Oh, and make sure the car is cold while doing this, you don't want to strip the aluminum heads if it's hot. Plus it's much easier on your arms. Prepare to scratch them up pretty good though.
And no, btw, I didn't re-use the factory heat shield on the plug boots.
Good luck!Last edited by StuntmanMike; 07-08-2010 at 02:30 PM.
07-12-2010, 07:18 AM #8Junior Member
- Jul 2010
- Columbiaville Michigan
Collector Yellow- 2002 C.E. T/A 1 of 488
GREAT INFO!!! I'm also planning on changing plugs. YES, #8 looks like a nightmare from the top.
07-12-2010, 07:28 AM #9
07-12-2010, 11:23 PM #10
read through Sarge's write up. His was on a GTO but a lot of the basics still apply:
http://www.ls1.com/forums/showthread.php?t=83551
07-14-2010, 09:31 AM #11
I just did the plugs on my 02 WS6. Driver side super easy as I am sure everyone knows, 6&8 not so easy.
6 was the hardest, I found that by removing the the AIR tube (super easy) and removing the lower stud for the 6 coil pack that opened thing up, aside from the AC lines being in the way.
As for #8, my brother did that one from below with no issues.
07-14-2010, 10:34 AM #12
when you start doing the plugs take your time don't rush it other wise is going to became a bet stressing. The first time that i did the plugs on my car it took me close to 2 hours. Now if I do them again it takes me like 25 minutes with out removing the coil packs..
Plug wire recommendations for my LT-1....
By jrgswhitels1 in forum General HelpReplies: 3Last Post: 08-19-2011, 07:53 AM -
Help after plug and wire swap
By stevesbucs205 in forum External EngineReplies: 4Last Post: 07-27-2008, 03:39 PM -
Plug Wire Removal
By KM02SS in forum External EngineReplies: 7Last Post: 04-11-2007, 07:59 PM -
Spark plug wire and plug!
By RYDER661 in forum General HelpReplies: 2Last Post: 03-13-2006, 09:01 PM -
Need a favor(I need ONE plug wire)
By Frosty in forum Parts Wanted / TradeReplies: 0Last Post: 01-22-2006, 07:10 PM
