Thread: another code
    Member ledesma54's Avatar
    Houston
    04 GTO
    another code
    Okay so the goat threw a code saying bank 1 sensor 1 low voltage and multiple cylinder misfire. Okay do i need a new a 02 sensor and since i don't have any cats can i just take the one's that are in the back and put it in the front. Also the engine light came on no big deal and then the engine light starts flashing for about 5 mins and the car starts sputtering and wanting to die at a stop kinda like a deep cam or something, and then go back to a solid engine light and it would be fine so do i have to just change the o2 sensor and that's it.
    I went to Playboy Mansion FantaZGuy28's Avatar
    Bakersfield/Long Beach Ca
    YJ
    04 GTO M6
    Cant help you with the 02 sensor, but the puttering and wanting to die could be caused by shitty gas. Any chance you put shitty gas or something other than 91 or higher?
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    So the tranny fixed itself. . . . . . . . ?
    Didn't you have some issue's with your 02's before when you did the header install? I can't remember. You could have someone monitor the cycling of the sensor to see if it is good. But if I remember correctly you didn't have any friends that had a scan tool to monitor your live PIDS or data.
    No friends @ AutoZone or Checkers?
    Retired Outlaw Sum Bitch
    Mine did that when the battery was shot.
    Houston
    04 GTO
    Ya the tranny is fixed, but when it started happening i plugged in the diablo and it wouldn't read anything from that sensor. Then i unplugged the battery and plugged it back in and its reading again and everything is back to normal so i don't know.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    What ended up being wrong with the trans?
    I would reflash the tune with your hand held also.
    Houston
    04 GTO
    Ya i burned all the gears in it, so i just payed for a stage 2 tranny with a shift kit. I guess the stall killed the tranny after only driving it for 6 hours lol. But its all good now. Ya i think i fixed the sensor prob so thank you
  1. Help: po 716 code on my gtp
    By SteveCZ28 in forum V6
    Last Post: 03-15-2012, 01:25 PM
  2. can someone look this code up for me
    By basballny2 in forum V6
    Last Post: 06-18-2010, 09:55 AM
  3. Code red!!!
    By Spikito in forum Almost Anything Goes
    Last Post: 10-03-2009, 08:23 PM
  4. Help with code
    By ledesma54 in forum Computer & Tuning
    Last Post: 03-28-2008, 03:39 PM
  5. Anyone ever have this code???
    By wheelszzz in forum General Help
    Last Post: 04-11-2007, 04:25 PM
