Thread: po 716 code on my gtp
02-07-2011, 11:38 PM #1Senior Member
- Jul 2006
- Greene, Iowa
Red- 99 Chevrolet Camaro Z-28
po 716 code in my 97 gtp came up yesterday....it is input turbine sensor parameters out of range...i dont know exactly what is causing this, or where to even begin. but for what ive read on the subject it causes the transmission to either not shift, or not shift properly/ thru all the gears. now heres what confuses me...my car acts like nothing is wrong, it shifts perfect like it has the whole time ive owned it. goes thru all gears, doesnt slam, slip or skip gears. tq convertor still locks up the way it should. so i dont know where to start or what to even do...ive seen some similar problems like mine that resulted in the tranny being removed torn down to replace a "reluctor wheel"? ive never torn into a a/t tranny before, and dont want to tear into it and mess it up, or find out i didnt need to tear into it....any help would be greatly appreciated here. thanks in advance guys
03-13-2012, 06:10 PM #2
Sorry I missed this man..
Here check this out if you have'nt already.
Though I am not sure if the 03's were still using the 4t65e or not.
So here are the rpo's. 4T65-E, 4T40-E or 4T45-E Transaxle (RPOs MN3, MN7, M15, M76, MN4, MN5)
Ontario Quebec Club Grand Prix • View topic - CODE: PO716 input/turbine sensor circuitLast edited by Smittro; 03-13-2012 at 06:16 PM.
03-13-2012, 06:22 PM #3
Everything I have researched suggests it's bad wiring to the sensor plug or the sensor itself.
03-15-2012, 01:25 PM #4I like turtles
- Aug 2007
- Corn and Soybean fields
Pull the side cover and ohm the wiring. The trans adaptation maxed code will probobly be thrown next from what you're saying.
An 03 is the same but not. Harness is a bit different but ohm specs etc should be the same.
Should I be getting a code?
By dlacey82 in forum Computer & TuningReplies: 7Last Post: 06-01-2011, 04:45 PM -
can someone look this code up for me
By basballny2 in forum V6Replies: 9Last Post: 06-18-2010, 09:55 AM -
Code red!!!
By Spikito in forum Almost Anything GoesReplies: 11Last Post: 10-03-2009, 08:23 PM -
Help with code
By ledesma54 in forum Computer & TuningReplies: 3Last Post: 03-28-2008, 03:39 PM -
Anyone ever have this code???
By wheelszzz in forum General HelpReplies: 5Last Post: 04-11-2007, 04:25 PM
