Thread: Help with code
03-16-2008, 04:02 PM #1
Help with code
Okay i just put in some LT headers with the mid pipes on my 04 gto, anyway the engine light came on and its saying that bank2 o2 sensor no activity, now is it because i have no cats now i just have mufflers. I have a Cold air intake, a 85mm mass air flow, the predator tune, and 1 chamber flow-masters. What sensors do i turn off in the predator.
Thanks in advance
03-16-2008, 05:24 PM #2Senior Member
- Jul 2005
- Jacksonville, FL
No cats will throw post-cat 02 codes, if that's what it is turn off the rear 02 codes for both banks. If it's a pre-cat (sensor 1) code check to be sure it's plugged in correctly. You need the front sensors, Predator won't let you delete those.
03-27-2008, 07:43 AM #3Junior Member
- Apr 2006
- Indiana
2001 Z28- 2002 SS
Take it to a shop and have them delete the codes for the rear 02's. If its a front sensor, you have a problem somewhere. The only problem you could have with fronts is the 02 heater code cuz they dont heat up quick enough with headers.
2001 Z28 FOR SALE
03-28-2008, 03:39 PM #4
You have to turn the codes off for B1S2 and B2S2.
Help: po 716 code on my gtp
By SteveCZ28 in forum V6Replies: 3Last Post: 03-15-2012, 01:25 PM -
Should I be getting a code?
By dlacey82 in forum Computer & TuningReplies: 7Last Post: 06-01-2011, 04:45 PM -
can someone look this code up for me
By basballny2 in forum V6Replies: 9Last Post: 06-18-2010, 09:55 AM -
Code red!!!
By Spikito in forum Almost Anything GoesReplies: 11Last Post: 10-03-2009, 08:23 PM -
Anyone ever have this code???
By wheelszzz in forum General HelpReplies: 5Last Post: 04-11-2007, 04:25 PM
