Results 1 to 2 of 2
    Senior Member kool-aide's Avatar
    Deltona, FL
    Sebring Silver Metalic
    2002 Camaro Z28
    a/c not holding vacuum
    ok, so i spent all night fighting with a new a/c hose, the big funky manifold one. I also put in a new dryer.
    the new a/c hose only came with on size of metal gaskets. The have a rubber inner section. This meant I had to use the old one for the small tube down by the radiator drain.
    that same tube was also too big so i had to sand it just a little.
    the bolt for the big tube connecting to the dryer was too short and started stripping the dryer threads. so i put in a longer lag bolt with washer and nut, because i couldn't find any thing in my junk to fit the threads.
    the new a/c hose came with three green orings, two one size and one that was smaller.
    when i took every thing apart i looked at each fitting. I didn't see any orings, so i didn't put new ones in, just the metal / rubber washer gasket things.
    i double checked all but on bolt, the one behind the compressor. all the bolts are tight.
    so after spending all night swearing and dying of concrete bruising i ran a vacuum test. I have one of those vacuum pumps you can rent with the gages and hoses.
    i ran it for 5 minutes, 10, 15, maybe not quiet 20. I noticed it would pull down to two marks before 30 Hg (don't know if i got that right but below zero). It would just sit there and not go any lower, just like before the repairs in which case I new i had a leak in a hose.
    as soon as i shut the valves and turn of the pump it returns to zero in a few seconds, maybe 20 or so. Not even minutes or hours, seconds. When I pull a vacuum it only takes a couple of minutes to get to 27ish 28ish that same spot, don't know if that matters how quick it vacuums down.
    i evacuated the a/c before i took any thing apart, and ran the same style vacuum test. So the system was empty, and is still empty.
    any ideas?
    how do i perform a UV dye test? Do I need a freon charge to do this? I know I will need about 1 oz of oil for the new dryer. But can I UV dye test without a full charge? I don't have a recovery tank, so that limits what I can do with any thing i put in the system that can't get out on its own.
    thanks
    kool-aide
    Deltona, FL
    2002 Camaro Z28
    well, to avoid spending another long day i spent the 18 bucks to have the local shop leak test it. it turns out one of the gaskets was bad / wrong. They replaced it, and all is well and ice cold. not too bad. I took a closer look at one of the left over gaskets. It certainly looks as if it goes on in a certain direction so when it compresses it makes a seal.
  1. Help: Trans Am engine Vacuum line for Vacuum/Boost Gauge
    By 1batt4u in forum General Help
    Last Post: 11-13-2014, 05:42 PM
  2. Help: lifter holding tool
    By canadavette in forum Internal Engine
    Last Post: 07-25-2008, 03:44 PM
  3. How are T56's holding up?
    By stanger88 in forum Manual Transmission
    Last Post: 05-16-2008, 06:32 PM
  4. Dipstick holding the Tranny?
    By JrockB4C02 in forum Automatic Transmission
    Last Post: 04-11-2008, 08:00 PM
  5. How is your 6speed holding up so far?
    By amit in forum Manual Transmission
    Last Post: 07-07-2006, 01:58 PM
