Results 1 to 16 of 16
05-28-2006, 11:10 AM #1
- Apr 2006
How is your 6speed holding up so far?
Well my rearend just went out on me i have 77k and im just worried about my 6speed going out on me soon because i hear they are alot of money to rebuild. but so far mine is shifting great i just changed to the royal purple syncromax and it does shift smoother when i would have problems getting into first gear.
05-28-2006, 01:19 PM #2
mine's been ok, i think i'll have to give that royal purple stuff a shot
05-28-2006, 02:59 PM #3
- Apr 2006
- yuma arizona
silver- 1998 Z28
i have 170k on mine. the guy that had it before me said he had the motor and tranny rebuilt, but didn't produce any paper work. so i assume that it's all stock. no leaks though. the engine/undercarriage, is cleaner than my 91 that only had 15k on the rebuild. everything seems to run well. it grinds a little going into third, but i think it's cause of the "cheap" cags mod.
06-22-2006, 05:15 PM #4
should be cheap enough if you do it in time, and then you can shorten 6 gear
when you are at it.
Doc
06-23-2006, 05:52 AM #5sbbuickGuest
From what I understand, the rear ends are outr problems. As long as you don't trash on the MN6, you'll be fine. Although, I only have 17k miles on mine so far.......
06-23-2006, 10:33 AM #6
- Pittsburgh, PA
that sucks your rear died before your clutch, amit. the t56 is pretty hardcore, and if you drive on street tires it should be OK, even with power adders.
06-23-2006, 09:54 PM #7
- THE SWAMP
95k+ miles with no problems
06-27-2006, 02:46 PM #8
- Apr 2006
yea i dont know if its an original clutch because the guy b4 me purchased the car from a chevy dealer with 55k on it and didnt put a clutch on it either and it grabs realy good. so im not to sure if its original but i hope its been replaced
06-29-2006, 08:16 AM #9
- Nov 2005
- Wilmington, De
Cyclone Grey Metallic- 2005 GTO
Sucks!
23k on it and it needs reubuilt. 4th grinds everytime when it's hot and it'll pop outta 3rd if it's PMSy that day.
Oh, my rear is shot too. Yah! So that will either be rebuilt or replaced with a 12 bolt.
The car has never seen the track or beat on that much. I baby it because I'm afraid to grenade something. Sigh
Engine runs like a horse, but everything behind it blows. I know the car wasn't beat on before i bought it. It only had 6800 miles on it and was a pontiac show car. Stupid car....Last edited by Selah; 06-30-2006 at 05:11 AM. Reason: dee dee dee I can shpell real gewd
06-29-2006, 10:45 PM #10
07-05-2006, 08:49 PM #11
- Jul 2006
- Possum Squat, Ky
'02 blue, '85 black&gold- 02 Firehawk #723,85 T/A
19k miles so far... 900 mi out of GM dealer overhaul and first time run going into fourth it locked in gear. Not the first time it's locked either! Started tearing it down 2nite.Pulled it twice before. First time to replace bent 3/4 shift fork and pads and then a snap ring on the 5/6. Roll pin on 1/2 fork this time I think. It's embarassing and frustrating recounting how many times I've missed third or fourth gear at the track. Need a rock crusher and a super shifter!!!
07-05-2006, 09:22 PM #12
- Apr 2006
damn that sucks i guess they were just not built right from the factory i know mine has gone 78k with out needing a rebuild shifts fine into gear no grind maybe alil notchy but that from the ws6store short stick.
07-05-2006, 11:43 PM #13
- Jun 2006
- Anaheim, CA
black- 1998 Camaro Z28
My 6 speed is starting to clash in 4th. Could the Chevy shifter be the problem? I hear it could cost me $2k for a rebuild.
07-07-2006, 06:55 AM #14
- Jul 2006
- Possum Squat, Ky
The clashing could be worn syncro teeth according to the Tremec Service Manual. There are other things too but, I dont have the book in front of me. I'll check the trouble shooting section later for more info.
07-07-2006, 12:11 PM #15
- CT
black- 2000 camaro ss+ 1987 GN
07-07-2006, 01:58 PM #16
- Jul 2006
- Possum Squat, Ky
I cant bang gears with the rail type vs a M-21 and a Super Shifter. Must be too many internal parts moving at once.
Found that the 5/6 retainer popped off the shaft AGAIN which I believe caused the demise of the syncro key (broken in half) which was located on the magnets during last nights tear down. GRRRRRRRRRR... tack weld...
Think I'll fill all the keys w/ weld and heat treat 'em. Better than paying 100 bucks for the aftermarket ones. (no offense D&D)... supply, demand and lack of cheese whiz! At least the Muncie keys are solid.
Help: lifter holding tool
By canadavette in forum Internal EngineReplies: 4Last Post: 07-25-2008, 03:44 PM -
Help: a/c not holding vacuum
By kool-aide in forum General HelpReplies: 1Last Post: 07-20-2008, 06:12 AM -
How are T56's holding up?
By stanger88 in forum Manual TransmissionReplies: 6Last Post: 05-16-2008, 06:32 PM -
Dipstick holding the Tranny?
By JrockB4C02 in forum Automatic TransmissionReplies: 4Last Post: 04-11-2008, 08:00 PM -
N/a Record Holding Z06 For Sale 600 Rwhp!!
By brent eb02 in forum Vehicles For Sale / TradeReplies: 1Last Post: 08-16-2006, 02:27 PM
