    Junior Member Darkknight86's Avatar
    Levittown
    2000 Z-28 Camaro
    My ASR/Brake/abs inop lights keeps goin on
    ok i'll start the car and everything will be fine, then bout 5 min lata the abs inop, brake, and asr lights go on. Does anyone have any ideas about what would cause this? and how to fix it?
    Pony Killer Insert's Avatar
    Mississauga, Ontario, Canada
    2002 Camaro SS M6
    could be a bad abs sensor.
    next time you're in the rain, slam your brakes check if abs works. but i would put my money on an abs sensor in one of your wheels...
    or it could just be dirt... abs sensor detects the little teeth on the rim of the rotor (little teeth between the two sides of rotor, tehy go around the edge of rotor... dont know how else to describe them). if you get dirt in there, it keeps the sensor from detecting the teeth going by, and thus your abs/low trac lights turn on..
    also what size tires are you using front and back... that can cause your abs to go nuts, because of hte difference in size, it detect each tire spinning at different speeds.
    but i would bet on a bad sensor.
    Tulsa,OK
    Quick Silver
    2002 Z06
    Yeah probably a bad sensor..
    Anyone know if the PCM has a code that it throws to tell you wich one is bad?
    On my 96 it does this in the rain every blue moon. Not going to fix it until it does it always.
    Camaro Owners Click Here
    Firebird Owners Click Here
    www.AutoTrix.net
    Royal pain in the.... Phantom2kz's Avatar
    savannah, ga
    2001 Z-28 A4 NBM
    2002 35th anni SS M6#1696
    the answer to both of your questions is in the E.B.C.M. not the P.C.M.
    You will need a tech 2 {gm scanner} or a higher $$ scan tool to get information from the ebcm. It will tell you what component is in need of further inspection/replacement..........
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    Quote Originally Posted by Insert View Post
    I'm not so sure slamming on youre brakes in the rain is the best way to test that out, but hey, maybe its just me
    if i were to use that method i would try gravel or a sandy area before i tried it in the rain
    2000 SS Black M6
    My ABS inop light comes on when i hit 100mph, anyone else have that?
    It stays on until i kill my car, its gone when i start back up
    2002 Camaro SS M6
    yup, i have this same problem on my dodge dakota, at approx 70mph. My problem is that my abs doesnt work. my abs and parking brake light up, i just dont feel need to fix it, it doesnt bother me. but first time it happened, it scared the shit out of me. i was on highway, and i look at guages and teh parking brake light was up... i think how did i miss that, pull the release with hand and its not coming off, at which point i thought i pulled the lever to pop hood. it was real funny.
  1. abs inop/tcs off lights on.
    By 02transamce in forum Drivetrain
    Last Post: 02-10-2010, 04:50 PM
  2. Help: 98 z28 asr,brake and abs inop lights on
    By pdiddyz28 in forum General Help
    Last Post: 09-20-2009, 01:57 PM
  3. ARS Off and ABS Inop lights....
    By JwMonE99 in forum General Help
    Last Post: 08-07-2008, 02:36 PM
  4. Error lights: ABS INOP and BRAKE come on randomly?
    By watson023 in forum Computer & Tuning
    Last Post: 12-08-2007, 07:21 PM
  5. ASR and ABS inop lights on
    By rampage76 in forum General Help
    Last Post: 09-30-2005, 07:00 PM
