Results 1 to 20 of 22
01-18-2007, 09:03 AM #1
Error lights: ABS INOP and BRAKE come on randomly?
I've had this problem on and off for the last, I guess, month. My ABS INOP and BRAKE lights come on randomly. Most of the time when I turn of the engine and restart the car, they go off, but sometimes, they come back on when I start it back up. I'd rather not spend a whole bunch at the dealership if anyone has had this problem before or has any ideas. Thanks.
01-18-2007, 11:48 AM #2
if the code is stored, maybe run by an autozone and see if they can pull it.
01-19-2007, 02:29 PM #3
Did you recently put on tires? I just put on new tires and the rear are taller than the front, thats why my lights are on. I wanna get this fixed, it is ugly having the lights on while youre driving.
P.S. mrr23 these wheels look awesome, i'll post some pics probably tomorrow.
01-19-2007, 04:28 PM #4Junior Member
- Dec 2006
- apopka, FL
black- 98 Camaro
if the abs inop light is on while your driving you will not have functioning abs. if you slam the brakes in this situation your wheels may lock. it can be any number of things, from a wheel speed sensor to the (ebcm)electronic brake control module(expensive). since it is only intermittant i would guess that the is electrically open or shorted internally. theres no way to know what it is exactly unless you scan for a trouble code.
01-19-2007, 05:25 PM #5
when this happened to me it was a grounding wire to the radiator support on the drivers side
02-07-2007, 03:17 PM #6Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
autozone wont be able to scan it. you need a bcm scanner. if you know someone with hpt or efi, they should be able to tell you what code it is. have you done any work to the rearend at all? I know when i changed my rear out for the 9", my light came and stayed on to this day
02-08-2007, 07:37 PM #7
Here's the low down: If the light is on, then your ABS is being turned off, generally not a problem, as long as you know how to stop your car without ABS, which almost everyone except soccer moms and other stereotypical drivers knows. The problem is when your light isn't on. If you recently change tires, then the braking proportion has changed, along with the weight gradient, and your rear brakes will lock before your front brakes. It will feel like you're using a big metal sponge to brake with... Many people ignore the lights, and don't worry about them, but since you have to be driving for a short while before the system recognizes the error, that initial time frame can lead to an accident, as it has with many (just search the forums). You either need to balance out the tire sizes front/back, or buy an ABS delete kit, then physically turn off the bulbs (since they'll always be on). Please, don't ignore this, it'll catch up with you.
She's baaaaaccccck...
'02 Z/28 M6 Hardtop
02-08-2007, 09:13 PM #8
03-04-2007, 02:15 PM #9
i had the very same problem. as you i checked all the wires. i found nothing. it wasnt until i was replacing the batter that i found the problem. one of the connectors where over tq'ed. i started to lossen the bolt and the whole barrel nut poped out. ever since the batter replacement its been fine.
03-05-2007, 02:26 PM #10
I took it to the dealer and was told that I just need a new brake control module or somethin. A couple grand...I can go without anti-lock brakes for a while.
03-05-2007, 05:03 PM #11
My lights still come on after I go over 55mph with my new wheels and tires. My car still stops fine.
http://i88.photobucket.com/albums/k1...98Camarod3.jpg
241's l Comp XER 230/230 Cam l SS4000 l Juice
03-06-2007, 08:47 AM #12
buy the abs module off ebay. you can pick them up cheap.
03-13-2007, 06:48 AM #13Junior Member
- Feb 2006
- Fredericksburg, VA
Black- 2001 WS6
You didn't have any work done to the rear did you? I had a similar problem when I destroyed my stock rear at the track and installed a Strange 12-bolt. Do you have Traction Control on your car?
After installing the new rear and finding that ABS/TC didn't work, I spent many hours and email to/from Strange to diagnose and fix the problem. What it ended up being is a design difference in the Strange/GM rear's. There's a Traction Conrtol Module that goes in the backing plate of the rear on each side. I found out by trial/eror that the sensor was sticking in too far in the backing plate, thus messing up the readings from the reluctor (sp?) wheel. I ended up installing 2 rubber o-rings as spacers between the backing plate and the TC Module. Fixed my problem, now I need to have a metal spacer made as the rubber o-rings are giving out and the sensor is at the smallest angle.
This may not have anyting to do with your problem, but something to check out.
-Bryan
P.S. I can include a pic of the sensor if you want.
03-13-2007, 06:42 PM #14SUPREME member-oderator
- Nov 2005
- Lost in Texas
Custom Slate Blue- 99 B4C
Have you changed tires or installed a stall converter recently?
03-13-2007, 08:28 PM #15
08-11-2007, 09:18 PM #16tattoo artist,esquire
- Dec 2005
- Huntington Beach, California
navy blue metallic- 2001 trans am
did you ever find out what this was? Mine is doing the same thing now, any help would be great!
08-13-2007, 11:13 AM #17
Yeah, it was actually my electronic brake control module (EBCM) which the dealership said would cost $1,000 plus, installed. I got a buddy at another dealership who can get it for me and install it for a total of $550 which is great!
Yours could be something else though, so if you can (without paying too much) you should run diagnostics on it to see exactly what it is. Could probably even be a wire (much cheaper than $500 or $1,000 I'm sure).
Good luck. Hopefully it won't be as expensive for you.
08-17-2007, 12:29 PM #18tattoo artist,esquire
- Dec 2005
codes that came up were C0550 ecu malfunction,C0896 device voltage range and U1301 communication. Any help from you or your buddy would be great!
08-19-2007, 08:26 AM #19tattoo artist,esquire
- Dec 2005
k, for those who follow and have the same problem, mine turned out to be the wire between the two fog lamps had corroded and the connectionneeded to be redone. Its the wire that runs in front of the radiator.
08-19-2007, 08:52 AM #20SUPREME member-oderator
- Nov 2005
- Lost in Texas
Another one: mine is because I have slicks and skinnies on and the rears are taller than the fronts. Without the same size tires front and rear, ABS cannot function properly because it doesn't really know when you're slipping based on wheels speed and you will get the brake light and ABS inop
Question: Lights/abs/inop
By 98maro in forum General HelpReplies: 9Last Post: 06-22-2010, 06:01 PM -
Help: 98 z28 asr,brake and abs inop lights on
By pdiddyz28 in forum General HelpReplies: 3Last Post: 09-20-2009, 01:57 PM -
ARS Off and ABS Inop lights....
By JwMonE99 in forum General HelpReplies: 7Last Post: 08-07-2008, 02:36 PM -
My ASR/Brake/abs inop lights keeps goin on
By Darkknight86 in forum General HelpReplies: 6Last Post: 06-19-2008, 08:22 PM -
ASR and ABS inop lights on
By rampage76 in forum General HelpReplies: 11Last Post: 09-30-2005, 07:00 PM
