    Member adham's Avatar
    Newport News, VA
    2000 Pontiac Trans Am
    just installed headers
    i just got MAC headers on my trans am and i was wondering what to do with the hoses that connect to the manifolds
    there are 2 hoses that connect to the passengers side manifold and 1 that connects to the drivers side
    the stock hose are too short
    i've heard many that have blocked these
    is that a good idea
    what will happen if i block them
    help please!
    NC
    4 cyl colorado
    The driver side and one of the passenger side are the air fittings, blocking them will throw an engine code but won't hurt anything. The other on the passenger side is the EGR, this too will throw a code. Try searching !AIR or !EGR this should turn up more details.
    Newport News, VA
    more help please
    Member keliente's Avatar
    Charlotte, NC
    99 Firebird Formula
    One is for EGR (passenger side) the other is for AIR.
    If you did not buy headers with emissions fittings then you will not be able to retain AIR or EGR. The headers with emissions fittings have little fittings that branch up from the header to meet the stock hoses.
    Deleting EGR and AIR will not hurt anything, but it will cause the SES light to illuminate until you have someone tune it out of the computer. The best way to fully eliminate EGR would be to pick up an LS6 intake manifold (01-02 cars came with it). That way you will gain some more power from the manifold, and also the EGR hole will already be plugged. If you can't afford one right now, stop by pep boys and pick up the correct size freeze plug, insert it into the manifold. You can then remove the EGR solenoid (the little cylinder shaped thing at the front) and tie the connector out of the way.
    The AIR system snakes all about the car. The pump itself lies under the drivers side headlight and is held on by three bolts. I believe it has an electrical connector as well. When you remove the pump you can follow the thick rubber tubing around the engine and pull it all out. The worst part about this is removing the little air box thing at the very back of the engine on the drivers side, it is kind of a pain to get to. And that's about it...
    Newport News, VA
    got it!
    thanks
    nc
    2000 camaro ss
    how do you like them?
    Newport News, VA
    i have a catted y-pipe so at idle there isn't much difference
    but when u hit or rev it its a different story!
    i notice a power increase as well
    nc
    2000 camaro ss
    AWESOME, i was looking at getting those,will you pass inspection???
    Newport News, VA
    yes, i think i will because i have the catted y-pipe
    also, the SES light is not on because the headers come with all the stock emissions fittings (AIR and EGR)
    they are also not too expensive ($700 shipped)
    nc
    2000 camaro ss
    hell yeah thats what i want, i wish they were ceramic coated.
    Member TwistedSS's Avatar
    Irmo, SC
    i hear that when you remove the AIR system, it will decrease the life of cats dramatically
    Newport News, VA
    thats true, the cats will go bad quickly, but i hooked up all the stock and AIR and EGR so i will be fine
  1. Headers & ORY Installed
    By SMWS6TA in forum External Engine
    Last Post: 09-28-2009, 03:25 PM
  2. installed headers
    By Siciliano15 in forum External Engine
    Last Post: 07-08-2009, 04:38 AM
  3. Headers Installed!!!!!
    By Y2KArcticSS in forum Camaro / SS
    Last Post: 08-14-2008, 06:38 AM
  4. headers installed...
    By Spaz in forum Firebird / WS6
    Last Post: 05-23-2008, 06:43 PM
  5. who's installed their own headers?
    By GottaHaveLS1 in forum External Engine
    Last Post: 08-12-2007, 06:11 AM
