    Member Siciliano15's Avatar
    NY/CT
    1998 Trans Am WS-6
    installed headers
    just installed the mac mids with catted y pipe this weekend. def not an easy job lol thats for sure. there is barely any room to work and everything was so close that i couldnt believe it actually fit. The directions on that website on how to install macs were not anywhere close either. they said to install them from the top but i tried for about a minute and it woulda never happened. they installed from the bottom but i had to cut and grind off those two tab things that stick out of the engine right below the spark plugs. once i got those off the headers went in kinda easy. still have a few adjustments to do because something very occasionally hits the bottom of the floorboard and has a slight rattle.
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    that good sir will be gone if you change your motor mounts..besides that i dont know what tabs your referring to..are you talking about the motor mount clams ?
    NY/CT
    1998 Trans Am WS-6
    there are two tabs. one under the #7 cylinder exhaust port and one under the #6 port. they are about 3/4 inch wide and 1/2 inch high and stick out about 3/4 inch from the block and they were the obstacle preventing the headers from smoothly going up into place.
    Shepherd, Michigan
    98' trans am
    Quote Originally Posted by Siciliano15 View Post
    hmm fair enough..i didnt even notice them when installing my QTPs...passenger and driver side slide in well...however i will have to do some more work on the k member ..since clearance is tight
    Decatur Al
    99 Z28
    Those are probably tabs that hold the block in the machining and and assembly process at the factory. They serve no purpose once in the car. I didn't notice them on mine either Shady.
    NY/CT
    1998 Trans Am WS-6
    lol well hopefully they dont serve a purpose cause i had to cut them down by about a half inch. had to do it by hand with a mini hacksaw too since the sawzall wasnt working. took me forever. as i was cutting it off i was hoping i wouldnt hit anything important haha.
    Shepherd, Michigan
    98' trans am
    shit..you would know already if that was the case
  1. Headers & ORY Installed
    By SMWS6TA in forum External Engine
    Last Post: 09-28-2009, 03:25 PM
  2. Headers Installed!!!!!
    By Y2KArcticSS in forum Camaro / SS
    Last Post: 08-14-2008, 06:38 AM
  3. headers installed...
    By Spaz in forum Firebird / WS6
    Last Post: 05-23-2008, 06:43 PM
  4. who's installed their own headers?
    By GottaHaveLS1 in forum External Engine
    Last Post: 08-12-2007, 06:11 AM
  5. just installed headers
    By adham in forum External Engine
    Last Post: 12-29-2005, 10:24 AM
