Results 1 to 20 of 49
Thread: Headers & ORY Installed
09-19-2009, 02:44 PM #1Spaz is My Mentor
Just finished installing my Pacesetter LT headers and ORY.
Many thanks to Chuckie669; your install guide helped a first timer soooo much!
I'll try to post so sound clips or a video later when I figure out how to do it from photobucket.
Other than that I am sooo
for now, Now what will my next mod be??
09-19-2009, 02:49 PM #2
Congrats did you run it open headers at first? Every one should get to do that at least once
09-19-2009, 03:02 PM #3
I was hoping it would help someone. Aren't you proud of yourself!!!
09-19-2009, 06:29 PM #4
Congrats on the install!
Did you upgrade or replace your motor mounts? I keep seeing posts where this is recommended and I am trying to determine if it is really necessary when installing LT's and ORY?
09-19-2009, 07:08 PM #5
Next mod is a mail order tune!
09-20-2009, 10:15 AM #6Spaz is My Mentor
Yes and I say it is a requirement for all that do a headers install. I think I was heard a mile away.
It was a great help!
I did not upgrade the mounts this time. However I see why some would do it. You are there and have most of the stuff out of the way so why not.
Yes, As soon as I get some more $$ It will be in the mail to yeah.
Now I have one more question.
The brace that was under the orginal Y pipe I could not reinstall. Any ideas on how to fix this. I was think of making some spacers and get some longer bolts. Any flaws with this that you can see?
09-20-2009, 05:52 PM #7
Congrats on the install..
I worked on mine most of the day, getting ready to put Pacesetters and ORY on..However I did decide to go the motor mount route..
So most of my days was getting the old exhaust off and changing one of the motor mounts. I have the drivers side done, thanks to my daughters boyfriend helping..It was a bitch to get that side lined up again to get the bolts in..
Next is to tackle the passenger side....sigh.
Have the exhaust off on that side, ready to move the other crap out of the way to get to the mount..
I am anxious to here what yours sounds like. Do you like to sound?
Don
09-20-2009, 06:15 PM #8Spaz is My Mentor
I have a video clip on this thread. Muffler is a Flowmasters (you will tell by the sound) For now the FM will do but I want a Magnaflow later.
My neighbor says I have the loudest car in our development
http://www.ls1.com/forums/showthread.php?t=122095
ALso I have what I think is the ORY slapping my floor boards when I WOT. I open to suggestions on how to fix that. I'm thinking on fabbing a bracket.
09-21-2009, 03:10 AM #9
Did the pacesetters fit the drivers side pretty good?
Or did you have to grind anything to make them fit?
Thanks
Don
09-21-2009, 04:57 AM #10
09-21-2009, 05:22 AM #11King 0f n00bz
- Jan 2006
- Shepherd, Michigan
be warned that the magnaflows coming off a catback is very tame..i am running magnaflow out of their catback, catless and it sounds tame until i get on it....it sounds great..just doesn't sound like catless and long tubes..but i electronic cut out will solve that issue when i want to be heard.
09-21-2009, 07:23 AM #12Spaz is My Mentor
I did the drivers side first, 1 because I had a friend helping and he had to go later in the day, and 2 because I wanted to get the difficult side done first.
I think I got real lucky because I didn’t have to jack up the engine move or cut anything to get them up there. I did scratch the firewall a little. The headers touch only in that spot and it was such a small amount I said F’ it and tapped it with my hand hard and it pushed right on thru using no hammer or another blunt object to apply the force needed to get it thru. A scratch of paint on a firewall no one will ever see doesn’t bother me at all.
Also with the tear down, I got every thing I could do on the top side done first. It is a pain in the ass jacking it up and lowering it down all the time. So I did every thing I could up top, then lift on stands and worked everything on the bottom. I am (5’7”) vertically challenge too just like TS|S so having the car an additional 20” in the air sucks.
In regards to the last spark plug on passenger side (#8 I think) I couldn’t reach it well enough from the top. So I saved it to do from the bottom. After I removed the Cats, starter, and factory Y-pipe it was so easy to remove. I didn’t take the starter all the way off. I used a wire coat hanger to hang it out of the way. Also with the headers it will make spark plug changes very easy in the future.
Oh, I just remember; Check your header bolts from Pacesetter. When I first put them in they would not tighten up at all. The new bolts bottom out, there was a 1/8th gap. I’m like
So I put them side by side. The bolts that came with Pacesetter have a thread all the way down the shaft. The OEM bolts come to a soft point. See picture. I used the OEM. I am sending these pics to Texas Speed and asking them about it.
Left side is Pacesetter Right side is OEM
09-21-2009, 08:16 AM #13
Wow Thanks for the bolt information. I was going to use the pace setter ones. Now I think I will clean up the OEM ones.
Thanks for all the tips...Hopefully I can get the other mount changed tonight and then work on putting the headers and y-pipe in.
You and I were waiting on the same parts from Texas Speed :-) We got them at the same time..
I'll post a video up when I am done. It will have the Pacesetter LT's, ORY, and Magnaflow catback..
I think I will run one of those bolts in tonight and see how far it makes it.
I, like you, did as much of the top work as I could before I raised it.
Thanks Again
Don
09-21-2009, 10:13 AM #14
09-21-2009, 10:47 AM #15
09-21-2009, 10:50 AM #16Spaz is My Mentor
I have a Flowmaster muff on now, with a tune will it take some of the rasp out.
Here is a vid
http://www.fquick.com/videos/Headers..._pre_tune/8969
09-21-2009, 11:25 AM #17
09-21-2009, 11:30 AM #18
09-21-2009, 11:36 AM #19
09-21-2009, 11:48 AM #20
Shady,
I am hoping mine sounds just like you described. I was happy with the sound of the stock exhaust and magnaflow catback. It could be a tad bit louder at idle, but I have no problem with that.
I went the header and ORY pipe now for future upgrades. I have a cam install in the future...already have the cam and some of the other parts...just need to build back up the funds :-)
Thanks for the info
Don
installed headers
By Siciliano15 in forum External EngineReplies: 6Last Post: 07-08-2009, 04:38 AM -
Headers Installed!!!!!
By Y2KArcticSS in forum Camaro / SSReplies: 14Last Post: 08-14-2008, 06:38 AM -
headers installed...
By Spaz in forum Firebird / WS6Replies: 32Last Post: 05-23-2008, 06:43 PM -
who's installed their own headers?
By GottaHaveLS1 in forum External EngineReplies: 21Last Post: 08-12-2007, 06:11 AM -
just installed headers
By adham in forum External EngineReplies: 11Last Post: 12-29-2005, 10:24 AM
