Results 1 to 3 of 3
Thread: Starting Issue
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Starting Issue
    Vehicle is my Dad's work truck, 2003 Express 3500 6.0L.
    It has been having strange starting issues. The starter sometimes hangs up after starting, so he installed a brand new Delco Remy starter. Does the same thing. However, I've read that its somewhat normal to have starter overrun on some of the newer GM trucks, since the ECU controls the starter.
    Other problem is there is a delay or no start condition sometimes when the key is turned. For example, you will turn the key and hold it, and after about 1 second, the starter will engage. Other times you turn the key over, and nothing happends at all. But if you turn it off and right back on again, it will start right up. Grounds and wiring have all been checked, and like I said, starter is brand new.
    Any help is appreciated.
    MOTOR CITY MARO' SSTODD's Avatar
    LIVONIA,MICHIGAN
    PEWTER
    2000 CAMARO SS #3821
    Ignition swich possibly? my G6 will "hang the starter" sometimes and I think the key switch is sticking.
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by SSTODD View Post
    Thats what I'm thinking. That seems like the only thing that would make it not send power down to the starter when the key is fully turned. If you turn the ignition off and back on again, this far it has always started right up.
  1. Starting Issue
    By DaEvil in forum General Help
    Last Post: 03-01-2013, 02:53 PM
  2. Help: Starting Issue
    By TA814 in forum General Help
    Last Post: 04-21-2009, 03:19 PM
  3. starting issue...
    By KongGMC in forum GM Trucks
    Last Post: 03-19-2008, 03:26 PM
  4. starting issue....
    Last Post: 02-24-2008, 05:41 AM
  5. 94 Z starting issue
    By 1st TA in forum LT1
    Last Post: 03-04-2007, 07:46 PM
