Thread: 94 Z starting issue
02-18-2007, 06:37 PM #1
94 Z starting issue
My boy has an 94 Z. The other day he said it would not start. The security light was flashing and the car would not crank. I was not here so I did not see what was done or anything. Do you think it would be ign. switch related or what? Any help would be great. It has started since then. Thanks
02-18-2007, 06:44 PM #2Member
- Sep 2006
- Central,Texas
Navy Blue Metallic- 2000 Camaro Z-28 SS
The first thing I would check is the battery and the cables.
02-18-2007, 06:49 PM #3
You think it would be battery related? Like I said the security light was flashing and the car made not sounds when he turned the key ( no clicking or anything ).
02-25-2007, 07:11 AM #4
It has only done it the one time. The security light was on, the car would not make a sound when you turn the key. Has anyone had this happen? Seems to be security system related but hoped someone would have some input.
Thanks
02-26-2007, 09:30 AM #5
That means the security system was tripped somehow. And when the security light comes on, the car will not start. I think you have to wait 2 minutes before trying to start it again. Mine did that about the same time the starter went out on mine. (Not syaing its realted or anything). But when I changed the starter, I've never had a problem since. The security light is still on til this day, but it starts everytime.
Some relate the 'security light' and no starting problem to a dirty key, which sends low signal to the ignition. I still haven't figured out why my security light is still on though.
03-03-2007, 06:43 AM #6
When you say a dirty key how do you have to clean it? Or is it more the ohm res. that the key has? Best way to clean?
03-03-2007, 09:02 PM #7
[QUOTE=1st TA;632832]When you say a dirty key how do you have to clean it? Or is it more the ohm res. that the key has? Best way to clean?[/QUOTE
http://shbox.com/1/how_tos.html
numbers 21-22-23 good luck
03-03-2007, 09:08 PM #8Bone it like you own it
- Sep 2005
- TEXAS... U mad?
Black / Stryker Blue- 2K WS.6/ 2K9 G8GT
my 94 camaro did it, turned out to be the ignition switch on the bottom of the column, the one that the key acctually works.
03-04-2007, 07:46 PM #9
Probably a VATS issue if its blinking...check the key pellet see if its clean, same for the key hole. if its gritty it wont read the resistance correctly, and it has to be +/-10% i believe.
do the obvious battery cable connection tests, clean the grounds and make sure enough juice is getting through the system... i had a semirelated issue that was a combination of a bad BCM aggitated by low connection that was multiplied in cold weather (below or near freezing)... but it ended up being a stuck relay in the BCM... i swapped BCM's and havent had a single problem since even in 10 degree cold starts.
Starting Issue
By DaEvil in forum General HelpReplies: 15Last Post: 03-01-2013, 02:53 PM -
Help: Starting Issue
By TA814 in forum General HelpReplies: 8Last Post: 04-21-2009, 03:19 PM -
Question: Starting Issue
By Wesman in forum GM TrucksReplies: 2Last Post: 06-12-2008, 08:10 PM -
starting issue...
By KongGMC in forum GM TrucksReplies: 3Last Post: 03-19-2008, 03:26 PM -
starting issue....
By KongGMC in forum GM TrucksReplies: 0Last Post: 02-24-2008, 05:41 AM
