Results 1 to 2 of 2
Thread: Alternator wire
    Member Orrin's Z's Avatar
    Post Falls, ID
    White and black
    2001 SS Artic white
    Alternator wire
    Long story short, car died so i pulled the battery and alt to have them tested, and i noticed that the plug for the alt was missing, i found one red wire comming out of the harness next the the injectors.
    well after testing, the alt was still good but the battery was shot
    and the guy told me that it should have the 4 pin connecter pluged in.
    i found a new plug in the glove box of the car from the past owner(had the car for 2 months)
    so it all falls to the new connecter has four gray wires. and i only found one red wire.
    so can anyone tell me where that one wire goes on the connecter and what the other wires are needed and where they go on the connecter??
    old timer blue02Z's Avatar
    2002 Z28
    not seeing it is tough, but how big is the 1 red wire? chances are its the charge back wire that charges your battery, hince why your battery died on you, it was running all your stuff for you. there should be a big stud coming out of the back of the alternator for it to bolt to. hope this helps
  1. A Fix if You Break your Alternator Wire Plu
    By SMWS6TA in forum General Help
    Last Post: 03-09-2017, 07:26 PM
  2. Question: Alternator connector, that little single wire?
    By TerribleTed in forum General Help
    Last Post: 01-14-2011, 06:08 AM
  3. Alternator charging wire!!!!
    By jb3golf in forum General Help
    Last Post: 05-22-2010, 10:22 PM
  4. Alternator issues - excitor wire reading 10V
    By 01 SS Vert in forum External Engine
    Last Post: 03-27-2009, 02:26 PM
  5. Help! broke alternator wire harness
    By 02Z in forum General Help
    Last Post: 10-22-2006, 03:34 PM
