10-22-2006, 06:23 AM #1Junior Member
- Jan 2006
- Michigan
Red- 02' Z28 M6
Help! broke alternator wire harness
I just got done doing my driver's side motor mount, so I took the car out for a ride, I am 2 miles into my drive and notice that battery isn't charging and I was running on battery power. Completely bummed, I took the car home and began to take the alternator off again, then after moving it a little, the wire (not the ground wire) broke at the harness, I did not take it off from the top before I took the bolts off like I should have. I followed battery disconnect procedure each time taking off the alternator. I would assume that the wire was damaged sometime during install, ergo the non-charging. What sucks is that if I fix the wire issue and find out that my alternator is toasted for some reason. Has anyone ever ran into breaking this wire, if so, I would appreciate some advice. I do have enough wire left to splice into a new adapter. If I had enough wire coming out of the adapter, I would of spliced it, but it broke right at the adapter. Thanks in advance.
10-22-2006, 06:57 AM #2Junior Member
- Jan 2006
- Michigan
Red- 02' Z28 M6
figured it out, I can re-use the harness.
10-22-2006, 09:35 AM #3
i did the same thing had to buy a new plug had no wire to work with. mine broke right off at the plug. alternator was fine
10-22-2006, 03:34 PM #4Junior Member
- Jan 2006
- Michigan
Red- 02' Z28 M6
That is a great link to have, thanks. I was able to splice the wire take the harness plug apart and was able to push the wire back into the blue plunger and re-hooked it up. I started the car and it was fine.
Ls wire harness
By jking78 in forum Parts Wanted / TradeReplies: 8Last Post: 03-07-2015, 05:30 PM -
Help: vacuum line broke when doing wire hide mod
By godless-phoenix in forum General HelpReplies: 9Last Post: 03-12-2012, 07:17 AM -
Wanted: LS1 Wire Harness
By MrKid in forum Parts Wanted / TradeReplies: 0Last Post: 07-24-2010, 05:58 PM -
Alternator wire
By Orrin's Z in forum External EngineReplies: 1Last Post: 06-08-2008, 07:03 PM -
Wire Harness Mod
By Long Drive in forum General HelpReplies: 11Last Post: 05-24-2006, 03:28 PM
