Results 1 to 20 of 25
    A Fix if You Break your Alternator Wire Plu
    Ok, here’s my first shot at a sticky. Long story short I was changing my alternator and I find that this plug came off with the alternator. It’s important; it tells the alternator when to charge and not charge. Without it you get nothing.
    After spending a couple hours at every auto parts store no one has it. Stealership wants me to get a whole new wiring harness. at him. So I decided to fix this. The wire came out of the plug, no breaks. So I cleaned the plug with electronic cleaner (Do not use brake cleaner, for those of you that don’t know why, it eats plastic) You then need to be very carefully and take the plug apart. Remember It’s old, been through many heat/cold cycles. If you break it your really screwed. I used fine point flat tip screw driver to pop the cap off. Next I used the same screw driver to push the metal pin out.
    Next I crimp wire of similar size to the metal connector. Length of wire varies in how much you need. For me it was 4 “ long. Next I solder the two for reinforcement. Now insert the metal piece with wire back into the plug. Next slide the blue rubber seal back on and down to the plug. Replace cap and orange seal.
    Splice and crimp old and new wire together, wrap with electrical tape to cover and help secure connection and then place back into wire cover. Clip back on to your alternator.
    This is what it should look like after it is back together.
    Ideally you don't want this to break, but accidents do happen and this only cost me some solder, a new solder iron, time, patients, and electronic cleaner.
    Pittsburgh
    2008 Hummer H3
    I think pic 3 is a repost.. j/k
    Nice job bro!
    Nice job bro!
    I used it, it was a good sequence, thx, I should have credit it to you in the first post. My bad..
    Pittsburgh
    2008 Hummer H3
    Wink
    I was just messin' witcha.. I stole your pic first..lol
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    Nice job.
    Only thing I would've done different is used shrink tubing in place of the electrical tape over the splice.
    And Smittro: I woulda used your sequence of events pic too. It's very good.
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    Quote Originally Posted by 67CamaroRSSS View Post
    Nice job.
    Thanx guys! I was'nt serious I was jus playin' round.. Glad I could actually help..
    I installed it when I got home, it works with no problems. Alt is charging, no twitching of needle and no check gauges light.
    I thought of using the heat shrink, but it's tight and I'd need a third person to maintain control of wires while I used a heat gun.
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    That's what I like to hear!
    Heat gun! We doan need no stinkin heat gun!
    Sorry I just had to throw that in there
    While a heat gun is the preferred method I've used a lighter to shrink tubing in more cases that I care to admit.
    I also have a roll of the type of non-adhaesive tape that sticks to itself similar to what they used on the cars way back when. It's been invaluable in more than 1 instance.
    The problem with electrical tape is that, over time the adhesive gives out. Be sure to check on it once in a while.
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    Farbic tape, (or tar tape) that stuff is the best (imho), electical tape ever made. They used that stuff on everything that had to be "open" sliced back then. You can get it wet and it will stuck to itself anyway.. It stay's put too.. If you wrap something up today and come back in 50 years you can peel it right off and put it elsewhere like the day it was new.. When I rewired our 100 yr old Victorian I peeled that suff off the old "knob & tube" wiring the house had it was STILL sticky... They even used it on overhead power lines because once it was (properly) stuck to itself is was wheather PROOF, not just resistant, but wheather PROOF!..
    Senior Member
    texas
    2000 formula
    i dont have a link.............but i have found the plugs on ebay.......cheap!!!!!!
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    You may be right. That is what the power window harness in my 67 is wrapped with.
    My guess is that SMWS6TA covered his with plastic tape though.
    Quote Originally Posted by sjsingle1 View Post
    what was the search you used?
    Yes...wanted something that would handle the wx...
    Senior Member
    texas
    2000 formula
    Senior Member
    texas
    2000 formula
    http://cgi.ebay.com/ebaymotors/98-02...item53d8cb1a5a
    another.......this seller has LOTS of TPI ....LS1 stuff
    Thx for the sites..
    Junior Member ared98ta's Avatar
    NEAR SEWER CITY IOWA
    Nice write-up!Thanks!
    Quote Originally Posted by ared98ta View Post
    Did you use it and did it help?
    No I had already bought an over priced connector to fix.Then a week
    later I found this thread and it would have been perfect had I seen it
    first.
    Bump..
    Ed and Mods, sinc the RSS feeds have been down, maybe look at this again for a sticky?
  1. Question: Alternator connector, that little single wire?
    By TerribleTed in forum General Help
    Last Post: 01-14-2011, 06:08 AM
  2. Alternator charging wire!!!!
    By jb3golf in forum General Help
    Last Post: 05-22-2010, 10:22 PM
  3. Alternator issues - excitor wire reading 10V
    By 01 SS Vert in forum External Engine
    Last Post: 03-27-2009, 02:26 PM
  4. Alternator wire
    By Orrin's Z in forum External Engine
    Last Post: 06-08-2008, 07:03 PM
  5. Help! broke alternator wire harness
    By 02Z in forum General Help
    Last Post: 10-22-2006, 03:34 PM
