    Springfield
    2004 SVT Cobra
    Engine temp gauge not working
    I noticed today my engine temperature gauge is not working at all. Im guessing its a loose sensor under the hood somewhere. Anyone know where to look?
    Senior Member
    Jacksonville, FL
    Check the ECT sensor connection/wiring - drivers side, brass sensor, right by #1 cyl in the head.
    Springfield
    2004 SVT Cobra
    Checked the ECT sensor and it looks fine. Lately the gauge has been working off and on. I must have knocked something else loose, this happened after i changed my spark plugs. Is the ECT the same sensor that monitors the coolant temperature?
    Senior Member
    Jacksonville, FL
    Yes, ECT is engine coolant temperature. Since it happened right after doing plugs it's got to be the connector or the wiring. You need to get it fixed, the PCM needs it's input.
  1. Want to trade Tranny Temp gauge for Oil pressure gauge.
    By jrbonds in forum Parts Wanted / Trade
    Last Post: 07-29-2011, 08:47 AM
  2. temp gauge isnt working and dash cluster question
    By laserredgt in forum General Help
    Last Post: 07-06-2010, 06:09 PM
  3. Hooking up Oil pressure gauge,and Temp Gauge
    By BirdFlewLS1 in forum General Help
    Last Post: 01-15-2008, 06:15 AM
  4. 3200RPM, temp gauge flat lines & engine bogs out
    By third_shift|studios in forum General Help
    Last Post: 02-19-2006, 03:38 PM
