07-06-2010, 11:34 AM #1
temp gauge isnt working and dash cluster question
car runs great, doesnt heat up, but the gauge is dead...all others are fine...could it be something simple or should i replace the whole cluster? and if i replace the dash do i have to get my key programmed?
07-06-2010, 01:53 PM #211 years of bangin gears
- Jan 2009
- North Jersey
You might have to check under the hood to see if you have a bad temp sensor. I dunno where the sensor is on Mustangs though. Could be mounted in the head, intake plenum or radiator.
07-06-2010, 01:54 PM #311 years of bangin gears
- Jan 2009
- North Jersey
You shouldn't need your fob to be reprogrammed if you were to swap clusters.
07-06-2010, 03:48 PM #4
Is the temp gauge all the way to the left?
My predicament seemed to point towards a bad gauge but it turned out my temp gauge actually gets caught on this piece of plastic to the very left and requires me to tap the dash to get it unstuck. It seems when I go to start it and the gauge resets is when it does this.
07-06-2010, 06:09 PM #5
the car is a 98 t/a, i will check the gauge this weekend but iirc it was all the way to the left like it was dead
Question: Gauge Cluster question
By SteveCZ28 in forum Stereo and ElectronicsReplies: 24Last Post: 08-01-2014, 01:38 PM -
dash cluster question..
By 98maro in forum General HelpReplies: 7Last Post: 05-17-2012, 04:07 PM -
Temp Gauge question
By robcas47 in forum Automatic TransmissionReplies: 4Last Post: 05-12-2011, 04:59 AM -
Question about gauge cluster...
By Brad(WS/Z0.6) in forum Firebird / WS6Replies: 18Last Post: 01-18-2009, 06:03 PM -
Engine temp gauge not working
By drummer52910 in forum General HelpReplies: 3Last Post: 06-09-2008, 08:13 AM
