Thread: Temp Gauge question
05-11-2011, 04:07 PM #1Army Dude
- Nov 2007
- Ft. Rucker Area, Lower AL
Arctic White- 01 TA / 06 Duc 749D
Temp Gauge question
Before my Cam/Stall install my car ran normally around 200ish, after the upgrades it ran at a consistent 210. Well last wednsday the xmsn shit out on me and I lost 3rd and she spiked in temp for a few seconds but came back down. I found a deal locally on a built xmsn so I swapped that one in and now the temp seems to be back at 210. I moved the extra xmsn cooler from where it was resting against the stock cooler and the temps came down to what I would guess to be 205 but still hanging around 210ish. My question is about the accuracy of the stock gauge, are the temps not accurate since the sensor isn't mounted in the pan? If so, how far off are they from what the actual temps are in the pan?
ASA Cam, Built A4, 3500 Stall, LT's, ORY, Hooker CB, E Cut-out, Lid, Modified SSRA, , SFC's,UMI Tq Arm w/relo, Spohn LCA's, 3.73's, Free Mods, Dyno tuned by James @ SpeedShift Performance. Need more suspension mods!!!
05-11-2011, 04:16 PM #2
Stock temp gauge on anything other than a '98 is a POS. Our gauge reads 205 degrees all the time when the actual temp is running between 183 and 196 degrees. Get a scanner on your car and check the temp with that.
05-11-2011, 04:23 PM #3Army Dude
- Nov 2007
I was thinking/hoping this was the case. Just need to hook up a scanner I guess. Thanks
05-11-2011, 04:24 PM #4
05-12-2011, 04:59 AM #5
Want to trade Tranny Temp gauge for Oil pressure gauge.
By jrbonds in forum Parts Wanted / TradeReplies: 7Last Post: 07-29-2011, 08:47 AM -
temp gauge isnt working and dash cluster question
By laserredgt in forum General HelpReplies: 4Last Post: 07-06-2010, 06:09 PM -
Question, temp gauge, running temps.
By hozeman in forum Camaro / SSReplies: 11Last Post: 07-27-2008, 01:20 PM -
Hooking up Oil pressure gauge,and Temp Gauge
By BirdFlewLS1 in forum General HelpReplies: 5Last Post: 01-15-2008, 06:15 AM
