Results 1 to 18 of 18
    gogo4
    Guest
    NOS Installation ?
    How complicated is it to install nos? I have never installed one before and just purchased the NX Wet kit doing probably a 125shot on my c5 mn6.
    Will I be safe with 125 on 91octane?
    Also where can i find some wiring diagrams or just installation help in general w ./pics etc ?
    Anyone noobie like me tried to go at it ? how did ya do?
    Don't Listen to Me NE98LS1's Avatar
    Nebraska
    if you have the money, i would have a tune shop do it, not only will they do a better job (especially if you have no experience, although a wet shot is fairly simple compared to direct port) but anytime you add that much horsepower, a tune is going to help a lot and they will get you all lined up and dyno'd!
    gogo4
    Guest
    i rather save the money and spent it on another mod then pay someone else to do something i can do myself?!?! thanx though
    Retired Outlaw Sum Bitch
    Quote Originally Posted by gogo4
    You can do it...take your time....
    http://www.hotrod.com/howto/3447/
    Yes anything under a 150 shot will do just fine on 92/3 Octane and a stock tune....lower the temps of your plugs one range cooler (pre detonation sucks)...Never hit it under 3000 RPM's.....or with the bottle pressure under 900lbs.....and you are good to go man...
    gogo4
    Guest
    thanx sarge .. btw these colours on the forum are getting me dizzy.
    Tell Ed...he is the one doing acid and listening to the Grateful Dead....not me....
    I'm out there so hide!!!! D!ck's Avatar
    TULSA, OK
    Black & Brilliant Silver
    1999&1997 SL600 6.0 V12's
    Talking
    [QUOTE=or with the bottle pressure under 900lbs.....and you are good to go man...[/QUOTE]
    what happens if it goes lower, I was told you just lose power.
    can you tell me a few does and donts. my cousin told me yesterday a good one dont hit the nos until fully warmed up or it could blow. see i dont know that little yet extremely important info
    plan on gettin a kit from summit in the after xmas sales& dont want to destory my baby
    Sure...bottle pressure under 900 could be an intermittant shot....you want a constant shot of nitrous and at least 900 lbs of pressure to insure your getting a steady flow of fuel and nitrous.....intermittant is a bad thing...causes "hiccups"...and that causes detonation/fried pistons/bent rods....stuff Santa probably wont bring you
    Basics.....
    Bottle Heater to insure proper bottle pressure..
    WOT switch to insure you only hit it at WOT...
    Purge Switch...to blow the air out of the line ( see low bottle pressure and "hiccups")
    Fuel Pressure Safety switch....if your fuel pump aint getting it done last thing you weant is a lean condition.....bad bad thing....FP Safety switch insures you shut off nitrous in case of low fuel pressure....
    Those are what I consider the basics.....safety is first man.....then hauling ass on giggle juice is very safe......and fun as hell
    This is my signature. It is mine. Nobody else has one like it.
    TULSA, OK
    Thumbs up
    Sarge
    Old Crazy Bastard
    thankyou your always there when us young punks dont know what the fuck were talkin bout
    Junior Member FloridaZ's Avatar
    jax FL
    Maroon
    2000 a4 z28
    Don't forget a window switch. That way all you have to do is flip a switch and floor it. Follow this diagram and you'll be set.
    gogo4
    Guest
    Thanx great info here!!!!
    So ... i am concearned what if on a cold day I am driving peacfully down the freeway and next to me is a brand spankin new viper that wants some ass whoopin.....????
    If i turn the heater on there will be no way that thing will work instantly unless i wait a few min right?
    Well its not going to happen I just want to turn it on and smoke it! lol that possible or is that too much risk.
    Btw my setup has all the safety stuff listed above.
    Member Orange SS's Avatar
    Palm Bay, FL
    Ermine White
    1964 Chevelle
    depending on the temp of the bottle,it's gonna take some time heat and build up pressure...even a new 300 watt heater
    TULSA, OK
    holly shit you the mu fuckin man, i can use that exact diagram
    N/A nitrously aspirated stangslayer98's Avatar
    miami,fl
    1998 trans am
    it does not take much time to build up presure on a bottle.....you could build up the presure with your on body heat youll be surprised how quick it builds up..............get a WINDOW SWITCH...must have
    miami,fl
    1998 trans am
    just to prove i wasnt talking crap i double checked the bottle was sitting outside 60 degrees......took maybe 30 seconds for the needle to move up
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by Sarge
    guess i better stop hitting it at 2k rpms then.
    Quote Originally Posted by mrr23
    Your motor...do what you want man.....Surgeon General tells folks about the effects of smoking and millions still smoke....call them stupid or whatever....sure...hit it under 3K....your lungs...I mean...your motor...take your chance...
    orlando, fl
    2014 camaro 2ss/rs
    been doing it for over a year on these two cars. the 3000 rpms is an old wive's tale. that and a legal disclaimer for the n2o companies. if the motor, and all else, can handle it, then have at it.
    it also has to do with how much you are using as well. would i hit a 400 shot at 2000 rpms? most likely not. a 50 shot? sure would. 200? hell yes.
  1. PAC SWI-PS installation
    By cascade in forum Stereo and Electronics
    Last Post: 08-03-2011, 05:41 PM
  2. Frc Installation
    By kebie05 in forum Appearance Section
    Last Post: 06-16-2009, 07:31 AM
  3. HELP! MAC ORY installation.
    By JoshieDoom in forum External Engine
    Last Post: 08-14-2008, 09:44 PM
  4. installation??
    By food nd cars in forum Internal Engine
    Last Post: 07-23-2006, 05:33 PM
  5. Lt1 Cam Installation
    By 96lt1z28 in forum LT1
    Last Post: 07-05-2006, 05:29 PM
