Results 1 to 20 of 23
Thread: Frc Installation
10-14-2007, 05:41 PM #1
Frc Installation
Anyone Know Exactly How To Install These? Any Tips Or Tricks? The Instructions That Came With Them Didnt Help To Much. I Am Starting To Feel I Paid All That $ For Nothing. Just For Me To Tear Up The Paint Job. That Is How It Went So Far. Thanks For Any Help..
K
10-14-2007, 06:00 PM #2
10-14-2007, 06:19 PM #3
so nothing needs to be undone (other than fuel lines) for the install? nothing bent?
10-14-2007, 06:23 PM #4
10-14-2007, 06:33 PM #5
it is like it is almost lining up and then it stops. what lines are supposed to go through the opening on them? seems like alot of stuff, wires, wire clips, and other stuff is keeping it from setting down.
10-14-2007, 06:34 PM #6
also trying to wedge it back far enough up under the cowl. that is what is causing me to tear down into the paint.
10-14-2007, 07:01 PM #7
Some people apply some blue painters tape or simply cover with plastic wrap to try to prevent scratching them during installation.
Wathc out for the sharp retainer pins under the cowl. They'll tear up your hands.
Which side is givin' ya trouble? Driver's side or passenger side?
Did you remove/move the wire bundles from both fuel line tubes & let them rest down lower?
Did you remove the throttle cable bracket from the intake manifold on the rear/driver's side?
Can you physically move the AIR tubing in the back of the engine under the cowl to allow more clearance?
Don't worry about the clips on the driver's side matching up with the coils. They won't, if ya line up the arches on the intake manifold. Once the c-clips are attached they'll stay put.
Also make sure the AIR tubing off of the exhaust manifolds are out far enough away from the engine. Again, simply bend them out carefully if necessary to gain more clearance.
Email me some details if ya need more help.
Ya should've called me or emailed to me. I'm always willing to help, ...
10-14-2007, 07:58 PM #8
it is just like there is alot of stuff in the way. if i remove the throttle body bracket, what holds the lines up?
10-14-2007, 08:04 PM #9
both sides are trouble. the trans fluid dipstick, how does that go? throttle cable bracket? how do these things stay put? do they just lay there? what c clips are you talking about? what air tubes?
10-14-2007, 08:06 PM #10
i just hope the messed up paint gets hidden.
10-15-2007, 05:38 AM #11
The throttle cable bracket is the one on the rear of the intake manifold on the driver's side, under the cowl area. It sticks up too high & won't allow the cover to snap on the fuel rail tubing.
If you remove the 10mm nut, the bracket will come right off. The cable will simply rest on top of the intake manifold.
(NOT THE THROTTLE CABLE BRACKET ON THE THROTTLE BODY.)
The rear of the passenger side cover has a relief for the A4 dipstick. The dipstick will move if necessary to get it to line-up.
The c-clips are molded on to the underside of the frc's. They snap on to the steel fuel line tubing.
The AIR tubes are the rubber tubing in the back of the engine running from one side to the other side, & the metal tubes coming up off of the exhaust manifolds.
I'll email some photos, ...Last edited by PontiacFan; 10-15-2007 at 01:46 PM.
10-15-2007, 10:35 AM #12
what do you mean a relief for the dipstick? where is it at?
10-15-2007, 01:50 PM #13
(Not 100% sure which dipstick ya mean.)
There is a hole for the oil dipstick. You can again, easily bend the diptick to the proper location so that it comes out thru the hole in the cover.
The auto trans dipstick coms out from under the top/rear of the passenger side cover.
Did ya check the email with the photos?
The covers are made in such a fashion that it's hard to tell the factory cuts for the Corvette, & the changes made for the F-body. The rear/top section of the passenger cover has the last arch cut-off for clearance for the auto-trans dipstick.
06-02-2009, 10:41 PM #14Junior Member
- Sep 2006
- Pearl City, HI
White w/Blue stripes- 99 Trans Am WS6 30th#1588
Drivers Side was a PITA....pics up soon!
06-03-2009, 12:15 PM #15Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
Old ass thread is old...
06-03-2009, 12:47 PM #16Member
- Nov 2008
- harrisburg pa.
black- 02 vette vert
06-03-2009, 12:56 PM #17
06-03-2009, 05:13 PM #18Junior Member
- Sep 2006
- Pearl City, HI
Same reason why people comment on why other people do it. It's not locked nor archived.......
06-03-2009, 05:16 PM #19
Glad you dredged this one up -- my FRC's should be here next week.
06-04-2009, 03:29 PM #20Member
- Nov 2008
- harrisburg pa.
PAC SWI-PS installation
By cascade in forum Stereo and ElectronicsReplies: 3Last Post: 08-03-2011, 05:41 PM -
HELP! MAC ORY installation.
By JoshieDoom in forum External EngineReplies: 2Last Post: 08-14-2008, 09:44 PM -
installation??
By food nd cars in forum Internal EngineReplies: 1Last Post: 07-23-2006, 05:33 PM -
Lt1 Cam Installation
By 96lt1z28 in forum LT1Replies: 2Last Post: 07-05-2006, 05:29 PM -
NOS Installation ?
By gogo4 in forum NitrousReplies: 17Last Post: 01-01-2006, 04:36 PM
