Thread: Simultaneous Hi/Low Beams
05-20-2008, 12:57 PM #1Junior Member
- May 2008
- Puerto Rico
Red- 1998 Camaro Z28
Anyone knows how to re-wire the headlights so both Hi & Low are turned on with the steering column switch in "Hi beam"?
05-20-2008, 02:14 PM #2Senior Member
- Feb 2006
- Orange County, NY
Painless wiring makes a kit that will do that. I think it is under 20 bucks and gives you directions, wiring and relays to to it right.
05-21-2008, 12:47 PM #3Senior Member
- Oct 2007
- Muncie, IN
00 TA PWTR, 98 VertTA NBM- 80 TA BLK, 80 Formula NBM
hmm. . . mine are both on with highs on. . . camaro's must be different. so would one set your "driving" lights and the other set your high and low beams?
05-23-2008, 07:18 PM #4
Somewhere theres a write up on how to make your driving lights, low and high beams all on at once when you hit the highs, but I can't remember where it is. Should be able to find it on here...
05-25-2008, 10:30 PM #5Crazy Canuck !
- Jun 2002
- Montreal, CANADA
I have that mod... it' a painless wire module... take any GM truck version of it and follow the instructions the same... works great... been with that mod for the last 5 years, at least... not 1 glitch since.
Eugenio_SS
05-25-2008, 10:43 PM #6
05-26-2008, 07:25 AM #7Junior Member
- May 2008
- Puerto Rico
Find the Painless Relay Kit! ...thanks Eugenio_SS!
05-26-2008, 11:53 AM #8
here you go......
- Under the hood, on top of the left fender liner, you will find a junction box with a bunch of relays.
- Find the relay marked "Fog Lamps". Under this relay you will find four wires - brown, yellow, purple and light green.
- Cut the light green wire.
- Attach a piece of wire to the end that goes to the relay and run it to a good ground.
- Tape up the other end of the light green wire to prevent shorting.
Now your fog lights will continue to work when the high beams are on.
Bear in mind that this is illegal in most states because you will have more
than four lights on at the same time when your high beams are on.
And dont put higher wattage bulbs (other than maybe the 37.5 watt ones)
because it will melt the plastic and ruin the housing.
05-26-2008, 11:58 AM #9
05-26-2008, 12:14 PM #10
05-26-2008, 12:21 PM #11
10-21-2008, 09:39 PM #12
i finally found this information i wanted to know how to do it
Help: No Low beams!
By weberje in forum General HelpReplies: 1Last Post: 06-24-2010, 07:51 PM -
All 4 headlights low beams
By BirdCountry02 in forum Firebird / WS6Replies: 11Last Post: 06-03-2008, 09:40 PM -
Help: Low beams keep blowing
By JoshieDoom in forum General HelpReplies: 11Last Post: 03-03-2008, 04:46 PM -
Brighter low beams?
By 99RedTa6spd in forum Firebird / WS6Replies: 12Last Post: 12-16-2007, 08:48 AM -
Hi beams and Low beams on at the smae time....
By SOMSS in forum Appearance SectionReplies: 5Last Post: 10-30-2006, 04:11 AM
