    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Low beams keep blowing
    Ive probably replaced my low beams 3 times since october... I have no clue why they are blowing other that constant use because I mostly drive it at night.. second shift/ DD. Im going to try a lot of dielectric grease on this one.. any other tips...
    no i dont touch the bulb.. got me a pair of those cotton car show gloves...
    check the sockets and make sure those are good. Both headlights are blowing at the same time?
    Beaver Dam KY
    79 T/A -91 Firebird
    low beams keep blowing... sockets appear fine. getting good 12v source.. i think i gonna get the harness/socket just to be safe.
    TEXAS... U mad?
    Black / Stryker Blue
    2K WS.6/ 2K9 G8GT
    are u still using the stock sealed beams?? or did you upgrade to the plastic housing with halogen bulb inserts???
    Beaver Dam KY
    79 T/A -91 Firebird
    Stockies.. im about to buy some hids because im sure they last longer/easier to change and im spending right at 14 a bulb everytime mine blows...
    harness/dielectric grease is comming up.. last time I changed the bulb that blew was around xmas...
    TEXAS... U mad?
    2K WS.6/ 2K9 G8GT
    touching a sealed beam is ok. its the halogen bulbs that "twist" in you dont wanna touch (i.e: our fog lamp replacement bulbs)
    Beaver Dam KY
    79 T/A -91 Firebird
    Its icing up a storm so I went drifiting and got my adjusters and 2 low beams... good to go now.. greased the crap outta them and now they appear to work quite fine.. just gotta put the covers back on when my knees that back out...
    thanks for all the help.. and gotta love the suttle differences in 98 cars..
    but i still ponder why my car loves eating bulbs all the time...
    Member ZForce1's Avatar
    Maine
    1999 camaro Z28
    my car was doing that for a while too. Started using the lube for the connector to prevent moisture from getting in and blowing the bulb and I haven't lost a bulb since.
    I have a need for speed! jigger1166's Avatar
    Standish,Maine
    Artic White
    00 SS Vert.
    Check the grounds on top of the radiator support. Make sure they are clean, and tight. They are for the headlamps respectively, one on each side.
    If the headlamp voltage has a hard time going to ground, it will cause the bulbs to burn too hot/burn out.
    Beaver Dam KY
    79 T/A -91 Firebird
    Awesome pic
    Junior Member VENUTO's Avatar
    Boston
    1998 trans am
    where can you getr hids for trans ams and how much$$
    casue i no they need to be seald beam
    Beaver Dam KY
    79 T/A -91 Firebird
    They dont have to be sealed beam.. you can get conversion kits.. i think there is a sticky on it.. lots of threads with many posts about them...
  1. Help: No Low beams!
    By weberje in forum General Help
    Last Post: 06-24-2010, 07:51 PM
  2. Question: Simultaneous Hi/Low Beams
    By Holden_Z28 in forum Stereo and Electronics
    Last Post: 10-21-2008, 09:39 PM
  3. Brighter low beams?
    By 99RedTa6spd in forum Firebird / WS6
    Last Post: 12-16-2007, 08:48 AM
  4. High Beams
    By Jay_dub87 in forum Firebird / WS6
    Last Post: 10-09-2007, 10:20 PM
  5. Hi beams and Low beams on at the smae time....
    By SOMSS in forum Appearance Section
    Last Post: 10-30-2006, 04:11 AM
