    Bad habbit- Smoking Fords
    South Florida
    Sunset Orange Metallic
    Hi beams and Low beams on at the smae time....
    I just purchased a Painless bypass kit made for 98'-02' GM's. Don't know if it will work but I'm going to find out next Saturday. Sick and tired of having no light in front of me if I use my hi beams. Our low beams go off when you put your Hi beams on and in my case my HID's go off and the road turns black. Wish me luck with this one.
    Compulsive F bomb dropper sgt0704's Avatar
    yuma arizona
    1998 Z28
    actually, there's a way to do it with out using a kit. i did it to my car.
    this was the advice given to me.
    "However, it's actually very easy to do yourself. All you need is a short piece of wire (14 gauge or thicker would be good) and a couple of ScotchLock connectors. Under the dash on the left side of the steering column you will find an 11-pin single-row connector (not all 11 pins are used). Just forward of that you will see a smaller square connector plugged into the column. It has three wires - light green, tan, and yellow. Use your short piece of wire to connect the yellow wire to the tan wire (don't disconnect or cut either wire, just splice them together). This will allow the low beams to remain on whether the dimmer switch is in the low or high position. It basically duplicates the way Firebirds are wired."
    i'm sorry you paid for the kit.
    South Florida
    I can send the kit back. Thanks for the info.
    2001 SS - 430 RWHP 412 RWTQ
    6 spd, FIPK, Corsa exhaust, LS7 clutch, Dart Pro PP LS1 heads, custom 220/224 cam, Kooks LT's. Ported TB, Full suspension, C5 ZO6 brake upgrade.
    Member SSmoky01's Avatar
    Central,Texas
    2000 Camaro Z-28 SS
    I thought it was illegal?
    Indianapolis, IN
    All Black
    83, 87, 02 All WS6 T/As
    How can it be illegal if 4th gen birds have it and my 3rd gen Camaro has it? I'm prtty sure its illegal to have fog lights on with brights though.. why I don't know....
    -Geno
    1983 Black WS6 "WindCharger"
    1987 Black WS6 "WS87"
    Sold the other four f-bodies
    South Florida
    There is no such law in Florida. The reason car companies don't do it is due to the amperage requirements of all those lights being on at the same time.
  1. Help: No Low beams!
    By weberje in forum General Help
    Last Post: 06-24-2010, 07:51 PM
  2. Question: Simultaneous Hi/Low Beams
    By Holden_Z28 in forum Stereo and Electronics
    Last Post: 10-21-2008, 09:39 PM
  3. All 4 headlights low beams
    By BirdCountry02 in forum Firebird / WS6
    Last Post: 06-03-2008, 09:40 PM
  4. Brighter low beams?
    By 99RedTa6spd in forum Firebird / WS6
    Last Post: 12-16-2007, 08:48 AM
  5. High Beams
    By Jay_dub87 in forum Firebird / WS6
    Last Post: 10-09-2007, 10:20 PM
