Thread: SES Code
    Member One_Bad_TA's Avatar
    Jan 2008
    Cleveland, Ohio
    2000 Trans Am WS.6
    SES Code
    For awhile now my SES turns on/off periodically. I keep throwing the code P0157 02 sensor circuit low voltage B2S2. Hooked it up to a wave graph and the voltage is at about 0.065 V and does not fluctuate while the other 02 sensors do. My question is: Is my 02 sensor bad or going bad andif so how much can i look to replace it for? Thanks
    Member stanger88's Avatar
    Shreveport, LA
    Black on black.
    2001 WS6 M6 (stock)
    Check the base of the catalytic converter. A lot of them rust/crack right there b/c the AC condensation runs down it. This will cause what you are seeing. If I am thinking right, B2S2 is right hand side (pass) and rear sensor, which sounds right for my possible diagnosis.
    If so, have a muffler shop weld it up and let the code clear, it will do so in a few hundred miles or so and then you will KNOW that you fixed it vs. just turning it off.
    TO check for this leak, when the car is cold, take a squirt-bottle or glass of water and throw it where I indicated (base of the cat where the pipe is welded on) and you should see bubbles. Do this after a cold start, obviously.
    Jan 2008
    Cleveland, Ohio
    2000 Trans Am WS.6
    There is a crack but not at the bottom of the converter its at the top of it by the exhaust manifold. But not sure if that was the reason why the light would go on/off a few times a week. Im gunna take of the cat and get it welded and see if its just like the crack at the bottom of the converter.
    Shreveport, LA
    Black on black.
    2001 WS6 M6 (stock)
    Quote Originally Posted by One_Bad_TA View Post
    EIther way, it would create an oxygen-rich atmosphere near the O2 sensor and this would lead to a "system low voltage". I assume you mean this crack is below the first O2, and above the 2nd? Sounds right. I think you have found your problem.
  1. Help: po 716 code on my gtp
    By SteveCZ28 in forum V6
    Last Post: 03-15-2012, 01:25 PM
  2. can someone look this code up for me
    By basballny2 in forum V6
    Last Post: 06-18-2010, 09:55 AM
  3. Code red!!!
    By Spikito in forum Almost Anything Goes
    Last Post: 10-03-2009, 08:23 PM
  4. Help with code
    By ledesma54 in forum Computer & Tuning
    Last Post: 03-28-2008, 03:39 PM
  5. Anyone ever have this code???
    By wheelszzz in forum General Help
    Last Post: 04-11-2007, 04:25 PM
