Results 1 to 20 of 44
Thread: Fans not turning on!!
05-07-2008, 01:21 PM #1Junior Member
- Mar 2008
- california
Red- 2002 Z28
been having a problem with the car heating up. i changed the thermostat and that didnt help. i checked the water pump and its not leaking. I also checked the head gasket and thats good too. I let the car sit at idle after running it hard and the fans didnt come on at all! I was just curious if you can just run a toggle switch for the fans to turn on and off?
05-07-2008, 01:26 PM #2Senior Member
- Nov 2006
- Indianapolis
More details please. What is your actual temperature? Can you access that with a scan tool? I think they won't be commanded on until 225 or so.
05-07-2008, 01:27 PM #3Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Turn on the AC and see if the fans come on.
05-07-2008, 01:40 PM #4Junior Member
- Mar 2008
- california
Red- 2002 Z28
the temp gauge usually goes a little past half way. but its weird cause when i go at high speeds and long distances it gets closer to the 7/8 mark.
05-07-2008, 01:47 PM #5Senior Member
- Nov 2006
- Indianapolis
You need to see your actual temperature. Could be a faulty gage/sending unit, air in your cooling system. Also, like Ed says see if they come on with AC on. They won't immediately, the high side of your AC must build some pressure first, so give the engine a 1500 or so high idle with your AC on to check the fans that way.
05-07-2008, 02:57 PM #6Junior Member
- Mar 2008
- california
Red- 2002 Z28
turned on the ac and the fans kicked in. have any ideas? i can smell coolant so i'm pretty sure its overheating.
05-07-2008, 03:19 PM #7Senior Member
- Feb 2006
- Orange County, NY
Could be the radiator cap.
05-07-2008, 04:33 PM #8
What does the temp do at a stop VS moving?
05-07-2008, 05:02 PM #9Junior Member
- Mar 2008
- california
Red- 2002 Z28
the temp stays around half way, a few degrees lower. you would think it would overheat all the time? no matter how far or fast you would go. why would it just go up after going at high speeds and long distances?
05-07-2008, 05:21 PM #10Member
- Nov 2007
- SATX
Pewter- 2000 Trans Am
if your temp is going up during driving, or highway driving your air dam might be obsturcted, or your plastic lip on the bottom of the car could be missing or broken, I would remove the pushlocks at the bottom of the bumper, and remove all the bugs/leaves. etc... out of the radiator's panel. your car shouldt heat up while driving (instead it should cool down once you start gong over 40mph) unless you have a leak, bad thermostat, Air in the Radiator, Bad AC Condencer or Compressor, or broken Heater Core.
If the temp is still rising you could have a faulty Thermostat. and if you still smell Radiator Fluid try checking the heater core it might be broken.
05-07-2008, 05:54 PM #11Junior Member
- Mar 2008
- california
Red- 2002 Z28
took the thermostat out completely now so i know thats not it. i will check the other stuff though thanks.
05-07-2008, 05:57 PM #12Junior Member
- Mar 2008
- california
Red- 2002 Z28
i took that plastic lip off, but what would that have to do with anything? the car was overheating prior to that
05-07-2008, 06:05 PM #13Senior Member
- Apr 2008
- Madison, WI
Overheating while driving means your not getting airflow to the radiator or you have a headgasket failure. Radiator airflow comes from under the car. Its hits the air damn and shoots up through the AC condensor and radiator. do you still have an air damn? If so you can take off the upper rad support and see down the radiator to see if its all clogged up with dust, dirt, leaves, etc and clean it out.
05-07-2008, 06:07 PM #14Senior Member
- Apr 2008
- Madison, WI
Low speed fan comes on at 226 F and High speed fan comes on at 234 F
05-11-2008, 03:47 PM #15Junior Member
- Mar 2008
- california
Red- 2002 Z28
took the car out and lasted about 20 miles until is basically hit the red zone! popped the hood and the radiator cap was bubbling pretty loud. i'm leaning towards a water pump but why isnt it leaking and why doesnt it overheat all the time?
05-11-2008, 03:56 PM #16Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Air in the system?
05-11-2008, 04:43 PM #17Junior Member
- Mar 2008
- california
Red- 2002 Z28
ed whats the best way to get rid of the air? i did change one of the radiator hoses.
05-12-2008, 03:16 AM #18Single Malt
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
www.installuniversity.com
follow the re-fill instructions given in the thermostat install
Air in the system will definately cause an overheat condition
05-12-2008, 08:12 PM #19Junior Member
- Mar 2008
- california
Red- 2002 Z28
i'm going to try that tomorrow bob. thanks again and i'll let ya know the result!
05-13-2008, 01:07 PM #20Member
- Jan 2008
- texas
White- 99Trans am
+1 air in the system
By NE98LS1 in forum Almost Anything GoesReplies: 0Last Post: 05-07-2010, 02:42 PM -
turning 30
By chuck4345 in forum Almost Anything GoesReplies: 40Last Post: 10-03-2008, 05:58 AM -
Help Fans arent turning on..
By eddielb in forum Western MembersReplies: 9Last Post: 02-18-2008, 11:20 AM -
Examined my cooling system. Fans are not turning on..
By Hollo in forum General HelpReplies: 8Last Post: 11-28-2007, 04:36 PM -
My radiator fans arent turning, help on how to troubleshoot
By Toneloc71sr in forum General HelpReplies: 6Last Post: 05-11-2007, 10:14 PM
