05-11-2007, 02:37 PM #1Junior Member
- San Diego
Red- 2001 WS6 Pontiac TransAm
My radiator fans arent turning, help on how to troubleshoot
So my car is overheating now that its getting hotter. I looked at on of my fans and it had some debris stuck to it preventing it from turning. I removed the debris from the one fan and they both turn by hand effortlessly. BUT when my car is on they dont turn on!! Even when my temp gage is in the red. I looked at the relays and I did notice something wierd ( can someone go out to thier car and check the positions??? ) The #1 and #2 Fan relays have the written upside down as I look at them from the front of the car. The #3 Fan relay is not upside down. Is this correct? Also, would having one of the fans stuck damage both fan motors?? Anything else I should check?? Thanks.
05-11-2007, 02:38 PM #2Story of My Life!!
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
Mine did that and it had blown a fuse.
05-11-2007, 02:45 PM #3
check the fuse and also see if you have power at the fan plug with a test light.
05-11-2007, 03:00 PM #4Junior Member
- San Diego
I looked at all the fuses in the two fuse boxes under the hood and the one inside the driver door. Didnt see any that were blown. I think one of them was labeled "fans", cant remember i was on the side of the fwy. I'll check again but anyone know the correct lable for these two fans? I read on another post that turning on the a/c would turn on both fans automatically so im gonna try that as well.
05-11-2007, 04:05 PM #5
my problem ended up being a messed up wire so i just ran a switch to the fans so i can turn them on when i want to and since i did that my car doesnt overheat so bad.. anyways i hope this helps
05-11-2007, 06:34 PM #6Junior Member
- San Diego
BLOWN FUSE, lesson learned, dont just look at the tops of the fuse, I pulled some out and looked at others thru the top
05-11-2007, 11:14 PM #7
Fans not turning on!!
By mrz28m6 in forum General HelpReplies: 43Last Post: 07-01-2009, 05:42 AM -
Help Fans arent turning on..
By eddielb in forum Western MembersReplies: 9Last Post: 02-18-2008, 12:20 PM -
Examined my cooling system. Fans are not turning on..
By Hollo in forum General HelpReplies: 8Last Post: 11-28-2007, 05:36 PM -
Wanted: Radiator and Fans
By Pman_75 in forum Parts Wanted / TradeReplies: 1Last Post: 06-18-2007, 11:17 AM -
radiator fans
By FastAssZ in forum General HelpReplies: 10Last Post: 08-14-2005, 10:30 AM
