    Junior Member Hollo's Avatar
    Chattanooga, TN
    1997 Trans Am M6
    Examined my cooling system. Fans are not turning on..
    Ok so i replaced the busted hose I had causing a coolant leak with a barb and 2 clamps.. and I examined the entire system, the leak is now fixed (i will definitely see after I drive around).. But my fans are not even coming on at all. and the temp got into the red after I let it idle for awhile, so it had a chance to turn the fans on. Where do I begin to check, trial/error?
    Also, when I first go for a drive (this has been happening since before I replaced this hose) The temp will climb up into the red zone about 260, and then all of a sudden after a few minutes of driving the temp will drop down to around 180-190 and stay there, which I'm guessing is when the thermostat is opening. Is that a bad water pump causing that or what?
    Ricekiller z28punk's Avatar
    Maple Grove, MN
    2002 Camaro Z28
    find the relays that control the cooling fans. there should be 3 of them. put a jumper wire across the relays to turn them on. if they dont work on any of them, then replace the fans. if they do work then it will get a little trickier
    sorry in advance for the oversized image
    Maple Grove, MN
    2002 Camaro Z28
    Chattanooga, TN
    1997 Trans Am M6
    I swapped a few relays around, and they still didnt work.. When I turned the AC on.. which it's supposed to..
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    could be the sensor on the block that tells the computer what temp the engine is at.
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    I would check the thermostat.
    Chattanooga, TN
    1997 Trans Am M6
    Thermostat was installed no more than 3k miles ago. Is there a way to test the coolant temp sensor without replacing it?
    Senior Member 35thAnniZ28's Avatar
    eating bulldog
    son of biscuit
    thermo might bec stuck
    Aug 1999
    No Where
    Then you probably still have air in the system.
  1. Help: 02 SS cooling fans
    By JaySleazy in forum External Engine
    Last Post: 11-08-2015, 08:41 AM
  2. Fans not turning on!!
    By mrz28m6 in forum General Help
    Last Post: 07-01-2009, 04:42 AM
  3. Help Fans arent turning on..
    By eddielb in forum Western Members
    Last Post: 02-18-2008, 11:20 AM
  4. LS1 Cooling Fans
    By oldsfreak in forum Parts Wanted / Trade
    Last Post: 03-05-2007, 04:59 PM
  5. Need LS1 cooling fans
    By Fire Chicken of Doom in forum Parts Wanted / Trade
    Last Post: 11-02-2006, 07:49 PM
