Results 1 to 2 of 2
Thread: 02 SS cooling fans
11-07-2015, 03:18 PM #1
02 SS cooling fans
I have owned my Camaro since 2003, the A/C compressor cracked 2 years ago because the fan wasn't turning on when the A/C was operational. I didn't notice anything out of the ordinary after that except the fans would get annoyingly loud. Last week I overheated and none of the fans were running. Come to think of it, I haven't heard the fans in months. if my computer isn't functioning correctly will the SLP manual fan harness eliminate any option of my fans not working?
11-08-2015, 08:41 AM #2Senior Member
- Apr 2010
- Alabama
It really comes down to why the fans aren't working as to whether that will work. I would personally want to figure out what the problem is before I put that on because there may still be some underlying issue that may cause that SLP harness to not work as well. I'd start with checking the wiring harness to the fans themselves first to see if that is the issue. Then check the coolant temp sensor see if that is causing an issue as well that caused the fans to not come on and work from there.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
Ls1/lt1 cooling fans
By QKRDTA3 in forum Parts Wanted / TradeReplies: 1Last Post: 07-03-2009, 05:58 AM -
Cooling Fans
By kraemer94 in forum General HelpReplies: 6Last Post: 09-18-2007, 07:40 PM -
LS1 Cooling Fans
By oldsfreak in forum Parts Wanted / TradeReplies: 4Last Post: 03-05-2007, 04:59 PM -
Need LS1 cooling fans
By Fire Chicken of Doom in forum Parts Wanted / TradeReplies: 0Last Post: 11-02-2006, 07:49 PM -
98 LS1 cooling fans?
By tigressws6 in forum General HelpReplies: 7Last Post: 03-19-2006, 02:55 PM
