Thread: Cooling Fans
    Houston
    Cooling Fans
    Any one know how I can turn on my fans and test all speeds with out having to like drive the car to get it to turn on? I'm think one of my fans might be causing voltage issues. I have a 2001 chevy SS LS1.
    Junior Member TwiSSter418's Avatar
    Florida mostly
    what I would do is find the plug for the fans, unplug it, and run a power and ground wire from the battery. ground the fan, and then apply power to whichever side on the plug is high and low. it'll make it spin at whichever speed and hopefully tell ya what you need to know...
    d
    2002 z28
    well i rigged a manual switch just using wires and connectors to my winter car but you get the idea
    Houston
    Cooling Fans
    Thanks for the reply! I will give that a shot.
    MOTOR CITY MARO' SSTODD's Avatar
    LIVONIA,MICHIGAN
    PEWTER
    2000 CAMARO SS #3821
    fans only run 1 speed when on, one fan will turn on at a certain temp and if the temp keeps rising to the next set temp the second fan will turn on. no speeds on the fans justy temp settings for when they turn on.
    Philly area
    Quote Originally Posted by SSTODD View Post
    I agree, and to take that further, the thermostat (stock 195F) tells it when the fan should kick in. I did a 160 thermo swap and HPTuners tuned the car for the fans to kick in 160ish F...
    d
    2002 z28
    if you have a diablo programmer that will work, just about all its good for beside some other stuff. but the way i showed you is just a way to bypass eveything to make it turn on when you want to.
    since my beater doesnt turn on till past it, and with almost 300 K on it i need it to stay cool
  1. Help: 02 SS cooling fans
    By JaySleazy in forum External Engine
    Last Post: 11-08-2015, 08:41 AM
  2. Ls1/lt1 cooling fans
    By QKRDTA3 in forum Parts Wanted / Trade
    Last Post: 07-03-2009, 05:58 AM
  3. LS1 Cooling Fans
    By oldsfreak in forum Parts Wanted / Trade
    Last Post: 03-05-2007, 04:59 PM
  4. Need LS1 cooling fans
    By Fire Chicken of Doom in forum Parts Wanted / Trade
    Last Post: 11-02-2006, 07:49 PM
  5. 98 LS1 cooling fans?
    By tigressws6 in forum General Help
    Last Post: 03-19-2006, 02:55 PM
